Flex-5000 PwrSDR access without Radio
If your old computer was running 2.7.2. Just copy the database file into the new computer 2.8.0 database folder and remove the RevQ database files that you see in the 2.8.0 folder. Then the first time you run PowerSDR 2.8, it will copy over the 2.7.2 database to the newer RevQ 2.8 database file. Even if you were running just an earlier version of 2.8. Just copy the RevQ database files you see from your old computer
The 2.8 folder: %userprofile%AppDataRoamingFlexRadio SystemsPowerSDR v2.8.0
The 2.7.2 folder: %userprofile%AppDataRoamingFlexRadio SystemsPowerSDR v2.7.20 -
Darrin, worked like a champ, thanks for saving me some time. New version looks great. Can you bring back the old "edge meter" as one of the selections? Works great for doing signal testing for me, I really miss it! 73 - Mike - KM0T
Just Left Click on the upper meter to cycle through all the meter types:
Dark BG Analog,
Bright BG Analog,
Medium BG Analog,
TR7,
Bar Graph,
Edge Analog
Then Right Click on the upper meter to BG colors and Needle type.73
Darrin ke9ns0
- 389 Community Topics
- 156 SmartSDR+
- 53 Aurora
- 970 Maestro
- 944 Genius Products
