Alpha 9500
Thurman Roberson
I plugged the alpha 9500 in the USB port on the back of the Flex 6700 but I dont see it at all any help in getting the radio to recognized the alpha
How did you set it up? Wired? Type of interface?
Some more details would help to see what is going on.
You might want to review the USB interface guide: http://www.flexradio.com/downloads/usb-cable-interface-guide-pdf/
Mike if I could call you or you could call me at 210-852-1826 I can explain it better that trying to type it0
Hi Thurman
I would love to, but I would be taking away work from the team in support.
You could also log a case in the support page and they will jump in.
I hope you didn't use the USB port on the back of the amp. That is not intended to interface with the Flex. It's intended to control the amp with a PC. You need a FTDI USB to serial adapter. Configure the amp for kenwood protocol and connect it using a serial cable... At least I think that's how it is supposed to operate from reading the manual (I only have a 91B, sorry).
Ria0
- 690 The Flea Market
- 197 SmartSDR+
- 112 Aurora
- 322 Shack Infrastructure
- 227 Networking
- 146 Contesting
