SmartSDR crashes when monitor goes to sleep
I would double check your settings as I suggest you are losing network connectivity. You can check this by trying to ping the computer over the network from another machine when the screen goes blank. Tony VK5TT0
Your network adapter might be going to sleep. Check the power option on the adapter.0
Also check power management in Windows 7. Try setting it to high performance. Dave wo2x0
Nope, it running 100% of time.0
Has been set to high performance sinc day one on this computer and OS.0
Checked all items and when monitor sleeps and is pingable up 100%.0
The i5 NUC seems to have a variety of issues like this. Enough variations that you'd have to do some research on your specific model, generation, driver and all that. It isn't just any one thing apparently either. 73 Steve K9ZW0
Is SmartSDR actually crashing or just disconnecting from the radio? If a true crash, could you post a screenshot of what you are seeing? This might help us to understand what is going on. Without that information, the others are on the trail of the most likely scenarios for this kind of issue (power management, power saving mode, etc). I understand WH6HI has this already checked this, but I include this here for others that may run into this same problem.0
I've been running dual monitors that go to sleep after 2 hours for 3 years will all versions of SSDR including all the ALPHA for the past 2 years with out a problem. I have set everything the like network adapter, USB ports etc to never go to sleep or to go power saving mode. The only thing that shuts down are the monitors.0
I wonder how Pat is doing with his problem?
HI all, thanks for sticking with me on this. Looks like the issue is in the ethernet. Can't figure out which setting are causing the issue. Power saving sleep etc. will keep looking.
thanks again for your help.0 -
There is a sleep setting in the driver itself that one has to change via the device manager. It sounds like you caught that, however.0
My solution for now is to just turn sleep mode for the monitor off for now. I am to busy with other things to continue the trouble shooting. So thanks to all that made suggestions. Not giving up just have lots of other things that need to get done.0
This is a last update, on a submission that I frankly forgot about. The reason is that as of version .37 and .39, I run 100%, no lockup’s no crashes always on, 24/7 and have had up time as long as 60 days with out issue. Only my local power provider has been less reliable. I do not have to worry that it will crash, making remote operation more feasible. Well, it’s almost perfect, except that in order to make remote operation really 100% reliable, one needs to invest in remote control devices to reboot systems if there is a crash or most likely an external event. I recently went back to the mainland after a long Covid delay to take care of urgent personal business. I was able to operate remote nicely until, power failed, long enough to crash the radio. I have UPS back up, but it only lasts so long, even with automatic computer restart. So, add this to my wish list, is automatic radio reboot and remote reset. But, in reality nothing is perfect, but improvements are expected. Of course all this perfection comes with cost. That is reality.
- 379 Community Topics
- 636 The Flea Market
- 140 SmartSDR+
- 260 SmartSDR CAT
- 199 DAX
- 44 Aurora
- 271 FLEX-8000 Signature Series
- 956 Maestro
- 57 FlexControl
- 301 Shack Infrastructure
