Don't see RF Power / SWR levels in SDR when transmitting phone
K1TZT
K1TZT Member
I'm using the Flexradio 6300 for phone operation for the first time .. I had previously used it just for digital modes and is working fine.   I have a USB headset for phone on my PC with SDR.  The issue I see is when I press "MOX" I don't see any RF Power level or SWR level outputs.  I do see my carrier signal in the signal display graph and the TX ready goes RED.   The  RF Power / SWR does show levels though when I press "TUNE"  Is it normal not to see any levels when TXing with MOX?
  • Larry _ NY8T
    Larry _ NY8T Member ✭✭✭
    edited July 2018
    If you don't turn dax off it will not pass microphone audio when using mox to key the radio.
  • Bill -VA3WTB
    Bill -VA3WTB Member ✭✭✭
    edited February 2018
    Select Pc in the input drop down  just above Proc button
  • K1TZT
    K1TZT Member
    edited September 2017
    Thanks for the quick replies..  I made sure I have both dax off and PC selected..  however I still don't see RF Power SWR level when pressing MOX only TUNE.   I attached screen "MOX" and "TUNE" in case you see something else I'm missing.  John K1TZTimageimage
  • Bill -VA3WTB
    In your computer, make sure default recording device is selected,,in audio devices and is showing response to you voice.
  • Tom    N5MOA
    Tom N5MOA Member ✭✭
    I don't generally press the MOX button, but my 6500 does the same thing..............until I speak into the mic.
    If you're speaking after pressing MOX and not showing any power out, I don't know what is going on.
    Tom N5MOA
  • Bill -VA3WTB
    If can't get audio from your computer,,do you have a mic to plug into the Flex?
  • W7NGA
    W7NGA Member ✭✭✭
    edited January 2018
    On SSB modes there is no output if audio is not present.
  • K1TZT
    K1TZT Member
    Thanks for the replies..  I checked the USB Mic more based on your feedback..   I found the gain wasn't high enough.  Once I increased I now see RF power level / SWR when speaking..  I was expecting the RF power level meter = to the RF power level  setting (100 Watts in this case) when keying the mic.. but it bounces a lot based on Mic level which looks expected then..   Thx
    John K1TZT
  • Bill -VA3WTB
    Ok glad it works, set the gain in the computer fairly high, then adjust the mic gain in SSDR were it should be.
