Don't see RF Power / SWR levels in SDR when transmitting phone
K1TZT
Member ✭
I'm using the Flexradio 6300 for phone operation for the first time .. I had previously used it just for digital modes and is working fine. I have a USB headset for phone on my PC with SDR. The issue I see is when I press "MOX" I don't see any RF Power level or SWR level outputs. I do see my carrier signal in the signal display graph and the TX ready goes RED. The RF Power / SWR does show levels though when I press "TUNE" Is it normal not to see any levels when TXing with MOX?
If you don't turn dax off it will not pass microphone audio when using mox to key the radio.1
Select Pc in the input drop down just above Proc button
Thanks for the quick replies.. I made sure I have both dax off and PC selected.. however I still don't see RF Power SWR level when pressing MOX only TUNE. I attached screen "MOX" and "TUNE" in case you see something else I'm missing. John K1TZT
In your computer, make sure default recording device is selected,,in audio devices and is showing response to you voice.
I don't generally press the MOX button, but my 6500 does the same thing..............until I speak into the mic.
If you're speaking after pressing MOX and not showing any power out, I don't know what is going on.
Tom N5MOA
If can't get audio from your computer,,do you have a mic to plug into the Flex?
On SSB modes there is no output if audio is not present.1
Thanks for the replies.. I checked the USB Mic more based on your feedback.. I found the gain wasn't high enough. Once I increased I now see RF power level / SWR when speaking.. I was expecting the RF power level meter = to the RF power level setting (100 Watts in this case) when keying the mic.. but it bounces a lot based on Mic level which looks expected then.. Thx
John K1TZT0 -
Ok glad it works, set the gain in the computer fairly high, then adjust the mic gain in SSDR were it should be.
- 113 SmartSDR+
- 922 Genius Products
- 124 Antenna Genius
