Smartlink stopped working
WA5YOM
Smartlink stopped working....I llogged out and logged in..everything looks normal....but never connects...
Maybe you need to re-register.0
Yea just log out and back in should come up.
Hi I have exactly the same problem. I have had it for last 3 or 4 days. The radio appears after logging on but after selecting it the iOS app puts you back to home screen. (Crashes?) You also cannot connect remotely from SSDR for windows from another location. I have tried logging out and back in but the problem persists. Powering the radio down remotely does not help. I am away from the home QTH at the moment and do not yet have Remote power control on the router or radio power supply so cannot try resetting the radio and router until I return.0
Are you guys using manual port forward or UPnP? If you're using UPnP try restarting the radio. If you're using manual forwarding be sure the radio's IP hasn't changed.0
I'm using UPnP. I can't do a full remove power reset at the moment as I am remote and haven't yet set that facility up. (First job when I get home
I am not uding UPnP....I re-registered...and it still doesn't work, and when I test the connection it passes...when I connect through my local wifi without smartlink...it works...Smartlink network settings are manual and still valid...0
- 378 Community Topics
- 116 SmartSDR+
- 37 Aurora
- 923 Genius Products
