Windows again!
The above URL directs you to Tim's recommended removal to initiate a new reload of SmartSDR. This, in my opinion, is the weak link in the chain in SmartSDR in that it takes so much time to do this and do it correctly. There might be a more remedial approach and I have been slapped on the hands several times with this recommendation.
Jim, K6QE
That is a little extream at this stage. Try restoring DAX first
https://helpdesk.flexradio.com/hc/en-us/articles/204017069-How-to-Manually-Re-Install-DAX-Drivers0 -
Looks like a great opportunity for someone (not me!) to write a batch file to accomplish this task.
Jim, K6QE
Good luck. Make sure you have all of the dependencies covered.0
I have all windows 10 updates and have never had any problems with my system using 6500.
I must be doing something right
Read the original post - ALL of his audio is gone. This doesn't sound like a SmartSDR/DAX problem to me but rather a sound system driver problem. Everyone is quick to blame Flex whenever the underlying Windows OS on their PC is at fault.
And, Tim, aren't there already uninstall/install batch files in the 3 DAX folders in "C:Program FilesFlexRadio SystemsSmartSDR v2.0.1764-bit Drivers"? I see they're dated from June of 2016, but they look fairly straightforward. Would these do what Jim, K6QE, requested, especially if they were chained together as one batch file?
I found that simply removing SSDR and reinstalling was easier than the 19 step DAX-only method!1
Try this: Right click on the speaker icon on the right side of the task bar. Click on playback devices. Scroll down to the bottom. Near the bottom click on "high definition speakers: right click and click set as default device. That has always worked for me.
Good Luck1 -
You are merely lucky. I went a long time with no problems, and now am getting hit a lot.1
I have found that the simplest thing is to use Revo uninstaller and deep remove everything. And I mean everything I do this as a sanity keeper, after every update because it's just easier than getting angry at the debacle tht is Windows 10.
Windows 7 still going without missing a beat. Of course, it doesn't get Microsoft's help any more.
The fact that Windows 7 doesn't get Microsoft's help is a blessing I think. That is why I will run Windows 7 as long as I can.1
I'm way down in the replies, so hopefully you will see this. Windows 10 often decides for you what driver is correct, and overwrites the one you were using. Then their troubleshooter looks at it and decides "Yes, you have a great driver, and this will work perfectly".
Problem is, it doesn't. You need to go to the manuuafcturer of your sound card, then download and install their driver for your card. This should get you back in business.
As for why it happens, after Windows updates "help you" I think Windows goes to the first sound driver in the system, and if it breaks, they all break.
Now you just hope it doesn't keep happening.
I dream of SSDR on Linux.2 -
If that's truly the case, go to Device Manager, select the sound card device, click on the Driver tab and roll the driver back to the previous version.1
Supposedly a rollback, also causes windows to stay on the rolled back version and not ever mess with that devices driver automatically anymore.
I'll try that the next time windows attacks.
73 Jay / NO5J
Hi,
I have been trying to attack this problem logically. I uninstalled SmartSDR and even some “ghost ports.” I think Greg, N8GD, is correct and it is a sound system driver problem.
This is what I know the audio for my computer uses for audio such as Pandora or my dictation program. In the Device Manager under Sound, Video, and game controllers I see the below.
IDT High Definition Audio CODEC
No drivers are installed for this device.
When I look at the “Driver File Details” I see
CWINDOWSsystem32driverskstrunk.sys
My thanks to all who have taken their time to reply.
What is the make (brand) and model of your PC. If you know that you can usually go to the manufacturer's website and download the audio drivers so you can manually install them. If you're not sure how to do that, see if you can come up with the make and model of the system and post it here and I'll see if I can dig up a driver installation package for you.
PS: I think the file you have is "ksthunk.sys" NOT kstrunk.
Greg,
Thanks to you I am up and running. I have an HP computer and their site was easy to use and I got the driver installed and learned I needed some other updates. It taken me this long because of other demands on my time. I had more time to myself when I was working Hi Hi. I am listening to my Flex 6500 on 75m at the moment. Thanks again.
"VC" KC0EM0 -
Your best source for drivers is the device's manufacturer, in this case, HP. Using generic drivers from the chip manufacturer "might' work, but what is supplied by HP is always the best course.
I'm pleased you got it working again. I know about having more time in the past: I used to run my own computer consulting and repair business for 15 years. Now that I'm retired I still take care of 7 of my own desktops, about 4 laptops, a few tablets, a couple of smartphones, and then there's about a half dozen PCs at our church and 4 systems I watch over for my good friend who's also my accountant. Plus there's all the PCs that I look at for friends and relatives when I travel several times a year. Hey, it keeps me engaged in the world of Windows, for better or worse!0 -
[quote] I think Windows goes to the first sound driver in the system, and if it breaks, they all break. [/quote] No. There's an actual algorithm, the steps and defaults for which vary depending on the version of Windows involved. Usually, Windows will select the most specific driver that the supplying vendor indicates matches your device, as long as it's passed all the Microsoft-specified compatibility tests (called the HLK or WHQL tests).
You can download th latest driver directly from a vendor website and use that directly, whether it's passed the compatibility tests or not. That's what I typically do. Usually, that newer version of the driver will be supplied as part of a future Windows update.
Peter
K1PGV1 -
,Greg,I think I'd go crazy if all I had to do was sit around and do nothing. It sounds like you feel the same way. I was glad to the HP website because it's even got some troubleshooting tools and keeps track of things needing updating, so I shouldn't have any problem with outdated drivers etc. Again, thanks for your help.VC, KC0EM0
- 323 Community Topics
- 577 The Flea Market
- 7.7K Software
- 6.2K SmartSDR for Windows
- 386 SmartSDR for Mac
- 253 SmartSDR for iOS
- 244 SmartSDR CAT
- 177 DAX
- 365 SmartSDR API
- 9K Radios and Accessories
- 125 FLEX-8000 Signature Series
- 891 Maestro
- 50 FlexControl
- 848 Genius Products
- 437 Power Genius XL Amplifier
- 298 Tuner Genius XL
- 113 Antenna Genius
- 269 Shack Infrastructure
- 190 Networking
- 134 Contesting
- 701 Peripherals & Station Integration
- 131 Amateur Radio Interests
- 924 Third-Party Software
