Router Setup for SmartSDR Remote Operation Using SmartSDR iOS
Wheelin Rev
Wheelin Rev Member
edited May 2020 in SmartSDR for Windows
I've almost got everything working between my iPhone remotely back to the FLEX-6500 station. Everything works fine as long as I am within range of my own Wi-Fi. I am down to just needing to get the Port Forwarding set up in the router for WAN operations.
- In layman's' terms, what EXACTLY do I put in the router?
- Do I use the 192.168.1.**** address locally for the radio or the computer?
- Or do I use the "external" IP Address like 74.62.****.YYY?
- Then, what TCP port number needs to be forwarded?
- How many entries am I going to make in the Port Forwarding table?
Please bear with me. Even though I'm an Electrical Engineer by degree, my illness is attacking the grey matter and making cognitive understanding difficult. I think this one last step and I'll be remotely operating from the hospital the next time I get admitted. At least, that is my goal.
Thanks for your help folks! I couldn't do this without you all.
73, Dave K4EET
[Edit #1]: I am running SmartSDR Version 2.0.17
[Edit #2]: This is a continuation of https://community.flexradio.com/flexradio/topics/need-help-with-verizon-actiontec-mi424wr-router which obviously I still have not done the router setup completely right yet.
  • Mark G Thomas
    Mark G Thomas Member ✭✭
    edited November 2019
    Hi Dave,
    For SmartLink you need two public Internet ports forwarded to the inside LAN (192.168.1.x) IP address of your radio base. If your router supports uPNP, then this can be done automatically by the radio, otherwise you would need to configure your router manually.
    public UDP port 4993 forwarded to your radio UDP port 4993
    public TCP port 4994 forwarded to your radio TCP port 4994
    That is a total of two port forwarding table entries.
    Hope this helps.  -Mark KC3DRE
  • Wheelin Rev
    Wheelin Rev Member
    Thanks for the replies. Look at the screenshot in this post:
    Those two ports were set up automatically by the SmartSDR install package.
    But there still seems to be something else that I need to do in the router to operate remotely. I'll see if I can find the reference that either Tim or Dudley made that I could not figure out.
    73, Dave K4EET
  • Ria
    Ria Member ✭✭✭
    edited August 2017
    Hi Mark,
    For SmartLink this will not work. Instead, in the SmartLink setup one must first select "manual" port forwarding and use the ports specified there. I believe SmartLink requires port 21000 or something similar and not just a straight 4993 or 4994 forwarded through.
    Riaimage
  • Jim Gilliam
    Jim Gilliam Member ✭✭
    edited August 2017
    The two ports are listed as the port numbers that you have to install in your router. You must be able to access your router to do this. Most routers have an address of 192.168.1.1 or something very similar. You access your router by entering that IP address into a program like Internet Explorer. Once you address the router you should get a page where you have accessed and can, now, port ward the router. Usually this is done under a WAN heading. All routers are different in the way you access the page to perform the necessary port forwarding.
    Jim, K6QE
  • Ria
    Ria Member ✭✭✭
    edited August 2017
    Dave -
    Based on that thread, I'm not even sure where the problem is.
    Are you able to connect at all?
    Are you connecting in "remote" mode and making sure you disconnect the radio at home first? If you connect while another client is connected you can use "remote" mode only where you will only be able to control the radio but you get no feedback as far as waterfall, panadapter etc is concerned. The best solution is to disconnect the radio from another client such as a PC or Maestro and then connect ONLY with the iPhone. There can only be one client connected at a time.
    Also make sure you are using only one router. Due to the way some ISPs like FiOS operate and require you to use their underpowered router, some people choose to add a router AFTER it and do double NAT. This will simply not work for SmartLink. Another switch is fine. Another router is not.
    If you are getting audio but no waterfall/panadapter, the router may not be passing fragmented packets. This is a problem in the router that they (ISP) may need to fix. Sometimes it's a problem in the client end. One of the wifis I use at work has this issue and the IT department has been unhelpful (I know the issue, they deny what it is, and they refuse to fix it.)
    Over to you.
    Ria
  • Craig_KØCF
    Craig_KØCF Member ✭✭✭
    edited August 2017
    Actually, SmartLink doesn't seem to care what number you put in for the external ports. I am using TCP port 4994 for both external and internal, and UDP port 4993 for both external and internal and it just works.
    Craig, KØCF
  • K5CG
    K5CG Member ✭✭
    edited August 2017
    Are you absolutely certain the IP address of your Flex is 192.168.1.10?
    Your subnet mask and gateway are correct?
    Settings->Radio Setup... Network Tab.
    If you are going to use manual port forwarding then the radio must be setup with Static IP settings (not DHCP).
  • Wheelin Rev
    Wheelin Rev Member
    edited May 2020
    To all of the above:
    The first screenshot is my router's Port Forwarding section. The two lines that reference FlexRadio were set up automatically during the SmartSDR Version 2.0.17 installation process. The second screenshot is the Settings ---> Radio Setup... ---> Network tab. I entered the information in the lower half of the dialog window and hit "Apply" upon which the radio rebooted. The radio's IP Address is definitely 192.168.1.10 on my home network.
    Those are the ONLY settings that have been changed so far. Is there one or more settings that need to be changed either in the Actiontec MI424WR router, my Norton Security software or elsewhere? Please be specific. Thanks for your assistance!
    73, Dave K4EET
  • Wheelin Rev
    Wheelin Rev Member
    edited August 2017
    Ria, everything works fine on my home network when the iPhone is connected to the router via the router's Wi-Fi. It is just when I am away from home and either at some place that has Internet connectivity via Wi-Fi or local to Verizon's 3G, 4G or LTE networks. 73, Dave K4EET
  • Ria
    Ria Member ✭✭✭
    edited August 2017
    I would either use UPnP or do the port forwarding exactly as SmartSDR recommends, regardless of what "just works" for others. The reason being that you want a supported configuration and this removes yet another variable. I also agree about double checking the IP of the radio. I would recommend static DHCP so that it remains consistent with router changes.
  • K5CG
    K5CG Member ✭✭
    edited August 2017
    Yes, that all looks to be in order.
  • Wheelin Rev
    Wheelin Rev Member
    edited August 2017
    Ria, where do I find the app that you displayed above with Network Settings? I've never seen that before. I'm wondering if that is the missing puzzle piece to make this work remotely. It appears to be set up that way in the router screenshot below but I'm curious to know where that window comes from. Thanks! Dave K4EET
  • Wheelin Rev
    Wheelin Rev Member
    edited August 2017
    Danny, it may all look to be in order but I'm still stuck in the "Discovering..." mode when trying to connect remotely. Something is missing somewhere... 73, Dave K4EET
  • K5CG
    K5CG Member ✭✭
    edited August 2017
    The only thing I can think of is to split the problem in half by trying to log in to another Flex user's radio with your client setup, and setting up another user to log into your radio with theirs. See which half is the problem.
  • K5CG
    K5CG Member ✭✭
    edited August 2017
    David, from the SmartSDR Startup page click on the SmartLink Setup button bottom right.
    Then click on the down arrow to the left of "Network Settings".
    If you are currently on Auto or Manual, try the test button.
    You can try the Automatic (UPnP) mode or Manual mode and see if you get a green light by the Test button.
  • Ria
    Ria Member ✭✭✭
    edited August 2017
    Yep. And if you are doing the manual port forward, make sure you select manual. It may work if you just leave it in auto and manually port forward, or it may not. Best to do it the way that is recommended.
  • Ria
    Ria Member ✭✭✭
    edited August 2017
    Dave, if you want to try my radio, I can give you credentials. I am good in QRZ. ALthough from all that has been said it looks like misconfiguration on the server (radio) end.
  • k3Tim
    k3Tim Member ✭✭✭
    edited August 2017
    "everything works fine on my home network when the iPhone is connected to the router via the router's Wi-Fi."
    Next step is to try connecting with the iFone not using WiFi.
    Could the problem be the ISP isn't allowing the ports thru?
  • Wheelin Rev
    Wheelin Rev Member
    edited August 2017
    I don't have a SmartLink setup button on my SmartSDR StartUp Page. See screenshot...
  • Wheelin Rev
    Wheelin Rev Member
    edited August 2017
    Solved the problem. You have to highlight the radio before the SmartLink buttons appear. Then I found out that this part had never been set up nor had the radio been registered. All is complete now. The next step is to wait for my wife to drive me to a few locations to see if I can now remotely access the radio. Thanks for your help Ria and Danny! This may have been the missing link. Thanks again! 73, Dave K4EET
    [Edit] Here is the SmartLink Network Settings:
  • Wheelin Rev
    Wheelin Rev Member
    edited September 2017
    Thanks to everybody that helped me on this topic. It turned out that I had never registered my radio with the SmartLink Network Setup. This just might be the missing link that was keeping the remote operations from working correctly. I'll know for sure the next time my wife takes me somewhere that I can try out the remote capability. The FlexRadio Community is the BEST! Thanks again to all! 73, Dave K4EET
    [Edit] Here is the SmartLink Window that was previously not set up. The radio was not even registered. My bad...
  • Ed, K0KC
    Ed, K0KC Member ✭✭
    edited August 2017
    Dave,
    You should be able to test your setup at home by turning-off wi-fi on your phone and trying to connect using LTE. I have done this several times previously when testing.
    Ed, K0KC
  • Keith WA0BEU
    Keith WA0BEU Member ✭✭
    Thanks, great comments!
  • Did you ever get this to work? I am having the same problem. I can log into my Flex from anywhere on my phone or laptop but when I am on my phone I have no TX audio unless I am on my LAN. No TX audio on cellular network.
  • ka9ees
    ka9ees Member ✭✭✭
    Sounds to me like you have the wrong mic selected.
