Is there a document how to communicate with the 6600M radio over TCPIP?
W8WD
I have a homebrew WiFi antenna switch controller/driver that manages my antenna and stack selections. I connect over TCPIP to get band & frequency information from my current radio so there no physical connection between the controller and radio. I have reserved a 6600M, Is there any documentation available to get started writing my driver for the 6600M?
Thanks!
Brian/W8WD
Thanks!
Brian/W8WD
I think you’re looking for the FlexLib API info. Although you might be reinventing the wheel - is SmartLink appropriate for your needs?0
There is an API but most have just sat down with the radio and wiresharked it.0
Eric, Thank you for pointing me to the documentation. I will be using the 6600M with PowerGenius XL and remote connection from Maestro, I am assuming 6600M TCPIP will support multiple connections from several devices including my application simultaneously.0
Absolutely. We do this already today with SmartSDR, DAX and CAT (all clients to the radio).0
- 637 The Flea Market
- 144 SmartSDR+
- 432 SmartSDR for Mac
- 261 SmartSDR CAT
- 200 DAX
- 46 Aurora
- 958 Maestro
- 57 FlexControl
- 932 Genius Products
- 302 Shack Infrastructure
- 141 Amateur Radio Interests
