Is there a document how to communicate with the 6600M radio over TCPIP?
W8WD
I have a homebrew WiFi antenna switch controller/driver that manages my antenna and stack selections. I connect over TCPIP to get band & frequency information from my current radio so there no physical connection between the controller and radio. I have reserved a 6600M, Is there any documentation available to get started writing my driver for the 6600M?
Thanks!
Brian/W8WD
Thanks!
Brian/W8WD
I think you’re looking for the FlexLib API info. Although you might be reinventing the wheel - is SmartLink appropriate for your needs?0
There is an API but most have just sat down with the radio and wiresharked it.0
Eric, Thank you for pointing me to the documentation. I will be using the 6600M with PowerGenius XL and remote connection from Maestro, I am assuming 6600M TCPIP will support multiple connections from several devices including my application simultaneously.0
Absolutely. We do this already today with SmartSDR, DAX and CAT (all clients to the radio).0
- 338 Community Topics
- 607 The Flea Market
- 7.9K Software
- 6.3K SmartSDR for Windows
- 170 SmartSDR for Maestro and M models
- 401 SmartSDR for Mac
- 264 SmartSDR for iOS
- 247 SmartSDR CAT
- 185 DAX
- 371 SmartSDR API
- 9.1K Radios and Accessories
- 19 Aurora
- 190 FLEX-8000 Signature Series
- 913 Maestro
- 886 Genius Products
- 320 Tuner Genius XL
- 116 Antenna Genius
- 281 Shack Infrastructure
- 197 Networking
- 137 Contesting
- 741 Peripherals & Station Integration
- 137 Amateur Radio Interests
- 954 Third-Party Software
