DAX 2.0.17 (remote)
KD7CAO
KD7CAO Member
edited February 2020 in SmartSDR for Windows
I thought in my little bit of downtime at work I would try to setup CW Skimmer for the Eclipse 2017. I keep hearing CW running on some of the 60M channels, presumably for the FEMA network running. I started to follow the instruction guide found online for setting up CW Skimmer and ran into a problem. My DAX is not connecting. I am operating remote, the radio is on a different network, but actually within the same building. Radio is connected to a FiOS network whereas I am connected to my enterprise network.
I am not sure what is wrong or why I can not seem to get the selected DAXIQ to show up under streams. At this point I am only trying to listen, not transmit.
  • George KF2T
    George KF2T Member ✭✭✭
    edited February 2019
    DAX is not supported via SmartLink in version 2.0.
  • KD7CAO
    KD7CAO Member
    edited August 2017
    Oh. I thought I read on another post that it was fully supported. So I am SOL. Okay. NP.
  • John WA7UAR
    John WA7UAR Member ✭✭✭
    There is an independent Mac version of xDax and xCat that was released and mentioned in these forums that does work with 2.0.
