Price of Upgrading to the 6600 from a 6300
Delbert McCord
Does anyone know what the (ballpark) price of upgrading to the 6600 from a 6300 is going to be? I have been reading here for a few hours and seeing fan issues with the 6300's with no real fix in sight. I think I remember seeing a post about the 6600 rigs not having fans on the CPU, is that true? Is it a direct replacement for the 6300?
Now that I am semi retired (health reasons) I finally have the time to play on the HF bands. I purchased a couple 6300's when they came out used them a little for QSOs but mostly monitored while I was working. Now that I am using them I had a fan problem.
I did not do much reading here (worked a lot) but now I am and I read about others having fan issues. As I read I find I should have taken the rig apart and clean it (which I did not do, I will do it from now on) and in my home we have 6 cats (non allowed in my shack) 2 dogs (hang out in my shack with me) and a Rabbit that used to live in my shack downstairs until my knee starting giving me trouble and now lives upstairs (its addicted to food and water).
My Home 6300 now will live in my Pole Barn in my man cave I built to load ammo in. I do my brass tumbling out side but I still have my Dog and she is out there 15 yours a day with me, that will not change!
Is the 6600 a upgraded 6300? Does it work basically the same, computer connected through the cat5 cable and slice receivers?
My real problem is now that I have had some time to really learn about my Flex and use it I really like it, I am at my cabin tonight meeting a service guy for the Furnace tomorrow and I just checked into the 80 meter net with the backup rig IC-746Pro which is a good rig but its no Flex 6300 (I took the Cabin Flex home when the one at home started giving me problems last time I came up here to mow the lawn).
So is upgrading to the 6600 at least for home a wise thing to do?
Oops I think I should be comparing to the 64000
As far as I know, the new models will have the fans as well.0
No,,the new models have passive cooling,,,
Price wise, you can call me in the morning at the main number, option 1, and I will be glad to discuss it with you.
Tim said the new models have passive cooling on the CPU and FPGA. Do we know if the PA also has passive cooling?0
This information on the 6400/6600 PA fan was previously posted:
Tim - W4TME, Customer Experience Manager
Official Response
The air flow dynamics for cooling the radios have changed in the 6400/6600. It should be quieter since we are using a larger fan.
It is a three wire computer case type fan. 80mm I believe.
You might also look at these comments on upgrading from the 6300 to the 6400:
https://community.flexradio.com/flexradio/topics/is-it-worth-upgrading-from-the-6300-to-the-64000 -
My best "ball park" guess is the cost of the radio on the Flex page minus $1200 for your 6300 as a trade in.
Tim,
Thanks.
I've never cracked open my 6300 but the noise it makes sounds like there are two fans. The most irritating fan runs constantly and cools the FPGA or ADC (I believe).
The other one is the PA fan that kicks in when/if needed.
First, is that even accurate, or is it one fan being ramped up when needed?
Second, what's the fan scheme in the 6400/6600, besides "quieter?" I.e., one fan or two?
Thanks a lot, really appreciate the info,
Rob
N4GA
Rob, from what I read, bigger fans in the new models make it quieter.
Rich,
That would be nice. I love the 6300 and don't need any more radio at this point, so not looking to upgrade.
But the fan noise is an embarrassment. The constant one, I don't care about the PA - I output like 5 watts into a LDMOS amp so it never comes on.
As soon as I'm off warranty, which may be now, not sure, I'm cracking that baby up and taking a look at quieting options. Maybe there aren't any decent ones..who knows.
Rob
N4GA
I started with a 6300 and upgraded to 6500 shortly after. My 6300 was noisy as well but was tolerable. the 6500 is much quieter and hoping the 6600m I have on order is better yet.
Rich
kd0zv
Thank you everyone that gave me information. I have now ordered a 6400.0
- 375 Community Topics
- 103 SmartSDR+
- 425 SmartSDR for Mac
- 999 Third-Party Software
