WSJT-x has stopped showing band activity
Bill -VA3WTB
Member ✭✭✭
It is receiving, it seems,,but it has stopped showing activity? when on monitor. what settings can i check?
2
I've had that happen a number of times too, where it just stops decoding. I usually fix it by closing the program and SmartSDR. I don't think I had to power cycle the radio. I can't remember.0
Could your time sync have gotten disabled? I've seen mine stop working if for some reason my meinberg time sync doesn't run.0
I have had it quit working because the Dax had stopped or was un selected, for example if you select a slice and it has gone from a dax 1 or 2 to none...you may have to reselect the dax line you want to use.
time sync? were is that?
Meinberg is software you download to help keep a windows machine in sync. Usually it is not that necessary but doesn't hurt. http://time.is will tell you if your computer's time is OK. If you are off by much (say 1 or more seconds) then it is time to consider something like Meinberg.
But, Greg's suggestion might be the first thing to try. For some reason, wsjt-x and even jtdx just kind of loses track of the sound device. I've restarted the app and DAX and things usually start working again.
Back on the time sync... when things start working again you can check the column circled and make sure that things are pretty close to zero.
As you can see from G6CHD's 3.2 sec difference you'd have to be pretty far out of sync before you stop decoding. I'm thinking restarts will help.
Kev K4VD0 -
I still can't get it to decode,,I don't know what changed...
That's been happening to me to. If you look at the waterfall when that happens you will see that the FT8 signals are all distorted (fattened). I've tried shutting down WSJT-X and SSDR but the only thing that fixes it is to power off and on the radio
Restart DAX, that should fix it. There are known issues with DAX and a restart usually fixes it temporarily.0
Dave W2OX said to check my computer for time, he said to check it with WWV. I decided to check time with my Flex GPS..that fixed the decoding problem.......
Bill, I don't have Flex GPS, but I do have NetTime which is a network time synchronization tool. I have updated this but it's still doesn't show band activity.
What did you do, adjusted your time with the computer?
Yes I did and it started working fine. But there is software out there that does this for you, getting the time from the internet. I have not bothered getting the software.0
Hi Dave,
If you can Facetime or Skype (I'll have to reload Skype) I can connect via TeamViewer and assist you in debugging your setup. I see you are in Ecuador so that would probably be the best way to do the support.
You can email me at wo2x AT arrl DOT net
and I will get back to you with my contact info.
I think it may be corrupted DAX settings in Windows causing no receive in WSJT-X.
- 382 Community Topics
- 632 The Flea Market
- 123 SmartSDR+
- 195 DAX
- 40 Aurora
- 953 Maestro
- 927 Genius Products
- 338 Tuner Genius XL
