Where is the USB cable menu on 6300
Delbert McCord
I have purchased a USB cable that I was told with work with my Flex 6300 (Null cable) but for the life of me I can not find the menu. I have not plugged in the USB cable yet. From the Manual I think I should find it in the Settings menu and there should be a USB menu but there is not. I know with computers sometimes it is bad to plug in a USB cable until the drivers are available for it.
Does the menu appear after a USB cable is plugged in?
Is your cable a genuine FTDI chipset cable? If so, it will work as soon as you plug it into your 6300. You should then see it in the 'Settings' menu.0
Yes it is and no I have not plugged it in yet. I was hoping this was the case but did not want to get the cart ahead of the horse. Thank You!
What is the cable used for?
Joe N9VX0 -
Plug the cable in. The menu will then be visible.0
- 633 The Flea Market
- 131 SmartSDR+
- 197 DAX
- 42 Aurora
- 955 Maestro
