Where is the USB cable menu on 6300
Delbert McCord
Delbert McCord Member ✭✭
I have purchased a USB cable that I was told with work with my Flex 6300 (Null cable) but for the life of me I can not find the menu. I have not plugged in the USB cable yet. From the Manual I think I should find it in the Settings menu and there should be a USB menu but there is not. I know with computers sometimes it is bad to plug in a USB cable until the drivers are available for it.
Does the menu appear after a USB cable is plugged in?
  • Paul - K6HR
    Paul - K6HR Member ✭✭
    edited August 2017
    Is your cable a genuine FTDI chipset cable? If so, it will work as soon as you plug it into your 6300. You should then see it in the 'Settings' menu.
  • Delbert McCord
    edited August 2017
    Yes it is and no I have not plugged it in yet. I was hoping this was the case but did not want to get the cart ahead of the horse. Thank You!
  • Joe  N9VX
    Joe N9VX Member ✭✭
    edited August 2017
    What is the cable used for?
    Joe  N9VX
  • Mike va3mw
    Mike va3mw Member ✭✭
    edited February 2018
    Plug the cable in. The menu will then be visible.
