Remote bandwidth usage of different solution
Marc Lalonde
i try to confirm and compare my finding on remote operation bandwidth usage
after a good day operation on 6M i see it used 70Gig data from 250 monthly limit !!
so i figure it time to see how to reduce it
for testing i receive band noise on 1 slice ,95RATE / 14FPS / 50AVG whit DAX 1 enable
each test is 30 minute
softether VPN default setup 500mb
softether VPN compresion enable 397mb
SmartLink 4296mb
SmartLink Low Bandwidth 2093mb
AnyDesk (kind of Teamviewer) 576mb
so assuming softether whit compresion and 8 hour per day = 190Gig/month
and whit smartlink = 2062Gig/month really need unlimited internet ;-)
did my result look good whit your own result ?
Best 73 Marc VE2OLM/VE2PN
SmartLink 4296mb
Puff, those seem very large numbers for Smartlink. They do not correspond to what I am seeing on my end. I will do some more testing and report back.0
Hi that why i post it here for make sure i not miss something
not forgot that i quite big Rate and FPS and have DAX Runing
ISP data Usage seem consistent whit that number
Didn't think DAX was supported over SmartLink yet?
Bret
WX7Y
good point just check and even if enable on radio it not streaming to local PC DAX
it would be interesting Marc when your testing, if having DAX on the radio increases the network traffic at all while running SmartLink?
Thanks OM
Bret
WX7Y
ok more test
running SmartLink whit ,receive band noise on 1 slice ,80RATE / 5FPS / 50AVG
and it drop to 318mb / 30minute
but really still not figure how smartlink may consume more that VPN ?
that no sens something must be wrong somewere0 -
i do more test seem i not able to duplicate previous extreme data usage ,still investigate that
look on last test that it more like 500mb / 30 minute for smartlink
softether whit compression stil the winner whit 230mb/30m (5FPS )
Hi Marc,
One more real-world data point....
Using just Maestro + SmartLink only over the WAN connection (No PC VPN, No Teamviewer, etc. in addition)
-30 minute test
-288 MB of billable data used (Verizon)
-So about 1Mbps
-95% of time Rx, 5% CW Tx
-Same panadapter framerate and waterfall speed as on the shack LAN
John, AF3K0
- 378 Community Topics
- 118 SmartSDR+
- 192 DAX
- 38 Aurora
- 947 Maestro
- 924 Genius Products
