Remote bandwidth usage of different solution
Marc Lalonde
Marc Lalonde Member ✭✭
i try to confirm and compare my finding  on remote operation bandwidth usage
after a good day operation on 6M  i see it used 70Gig data from 250 monthly limit  !!
so i figure it time to see how to reduce it
for testing i receive band noise on 1 slice ,95RATE  / 14FPS / 50AVG whit DAX 1 enable
each test is 30 minute
softether VPN  default setup               500mb
softether VPN  compresion enable     397mb
SmartLink                                          4296mb
SmartLink  Low Bandwidth               2093mb
AnyDesk  (kind of Teamviewer)          576mb
so assuming  softether whit compresion and 8 hour per day = 190Gig/month
and whit smartlink   = 2062Gig/month   really need unlimited internet  ;-)
did my result look good whit your own result ?
Best 73 Marc  VE2OLM/VE2PN
  • EA4GLI
    EA4GLI Member ✭✭✭
    edited August 2017
    Puff, those seem very large numbers for Smartlink. They do not correspond to what I am seeing on my end. I will do some more testing and report back.
  • Marc Lalonde
    edited August 2017
    Hi  that why i post it here for make sure i not miss something
    not forgot that i quite big Rate and FPS  and have DAX Runing
    ISP  data Usage seem consistent whit that number
  • WX7Y
    WX7Y Member ✭✭✭✭
    Didn't think DAX was supported over SmartLink yet?
    Bret
    WX7Y
  • Marc Lalonde
    edited August 2017
    good point  just check and even if enable on radio  it not streaming to local PC DAX
  • WX7Y
    WX7Y Member ✭✭✭✭
    it would be interesting Marc when your testing, if having DAX on the radio increases the network traffic at  all while running SmartLink?
    Thanks OM
    Bret
    WX7Y
  • Marc Lalonde
    edited August 2017
    ok more test
    running SmartLink  whit ,receive band noise on 1 slice ,80RATE  / 5FPS / 50AVG
    and it drop to 318mb / 30minute
    but really still not figure  how smartlink may  consume more that VPN ?
    that no sens something must be wrong somewere
  • Marc Lalonde
    edited August 2017
    i do  more test  seem i not able to duplicate previous extreme data usage  ,still investigate that
    look on last test that it more like 500mb / 30 minute for smartlink
    softether whit compression stil the winner whit 230mb/30m    (5FPS )
  • John - AF3K
    John - AF3K Member ✭✭
    edited August 2017
    Hi Marc,
    One more real-world data point....
    Using just Maestro + SmartLink only over the WAN connection (No PC VPN, No Teamviewer, etc. in addition)
    -30 minute test
    -288 MB of billable data used (Verizon)
    -So about 1Mbps
    -95% of time Rx, 5% CW Tx
    -Same panadapter framerate and waterfall speed as on the shack LAN
    John, AF3K
