Smartlink & Flex6300 problem.
Gianluca Ianni
Hi guys ! I have update the last V2.017 firmware on my flex6300 but I have the problem with the port TCP & UDP on Smartlink connection .
I enable the UPnP on my router but the test is KO , also I enable the forwarding ports but the test is KO .
This is the firmware problem on Flex6300 or ISP problem ??
TNX de IK6QOO Gianluca
Did you register your radio with Smartlink? That is the procedure where you have to key your radio locally to be recognized as a valid ownerr.
Jim, K6QE
Gianluca
It is not very clear what problem you are experiencing. Can you post a screen picture of the problem you are seeing? I am not sure what KO means.
You might want to try rebooting your radio as well and see if you have the same problem as that will ensure that uPNP registers with your firewall.
However, to answer your question, no, there is not a firmware problem. I am unsure about your ISP.
73, Mike va3mw
Gianluca - Something I discovered with my SmartLink setup was that once I made a change on the network settings panel (choose auto or manual port forwarding), I need to 'Save' my change before I could test it. Also, I was baffled by why there were '-1's in the two port fields, it wasn't obvious to me that I needed to pick two unique external ports to forward to the radio. Once I set the network config to 'manual' port forwarding, set the two ports to be the same internal and external (4993 & 4994), and established a port forwarding rule in my firewall directing those two ports to my Flex 6300's IP address, I got the green light. Hope this helps, Ken, N2VIP0
The "-1" indicates the radio does not have any values for the TCP and UDP ports.0
Thank you all !!
My flex 6300 is registered on smartlink , the KO is the red when i send the test , in manual mode i replaced the -1 value with 4994 & 4993 ports and i redirect this port on router ports forwarding.
Other port forwarding services work well .
My doubt is a firmware bug of 6300 or ISP problem ??
Gianluca, I'm confused, you are properly routing each port with the proper message traffic (TCP & UDP), and still having problems? Please clarify, and also please explain how your radio is connected to the internet - I suspect you are set up as: ISP -> modem/router -> network switch -> flex Correct?0
my setup is :
ISP>modem/router>flex6300
I redirect the 4994tcp to 4994/IP_Flex6300 and 4993upd to 4993/IP_Flex6300 but the test is RED
also i enable the UPnP on mt router and i set to automatic but the test is RED .
I suspected the problem is my ISP .0
- 246 Community Topics
- 488 The Flea Market
- 7.3K Software
- 328 SmartSDR for Mac
- 241 SmartSDR for iOS
- 224 SmartSDR CAT
- 161 DAX
- 343 SmartSDR API
- 8.5K Radios and Accessories
- 768 Maestro
- 42 FlexControl
- 726 Genius Products
- 251 Tuner Genius XL
- 84 Antenna Genius
- 223 Shack Infrastructure
- 150 Networking
- 118 Contesting
- 116 Amateur Radio Interests
- 810 Third-Party Software
