ZZFR command malfunction
Sergey R5AU
ZZFR cat command not working as defined, but just toggle from active B to A (SSDR 2.0.17)
Sergey is this what you are talking about?
<macro><Button>TX Slice A</Button><Command>ZZSW0;</Command></macro>
<macro><Button>TX Slice B</Button><Command>ZZSW1;</Command></macro>
Clay you are right , however ZZSW 0/1 need 2 dedicated macros instead one with ZZFR
Sorry Sergey not familiar with that command.
Only thing I could find on it lends me to believe it was from PowerSDR, maybe not compatible with SSDR?
Clay, I follow with SSDR CAT UM http://www.flexradio.com/downloads/smartsdr-cat-user-guide-pdf/ chapter 4.1 , both commands are presented and I appreciate to use single button on my external keypad to toggle between A/B. On the fact you can just once switch active from B to A and no more else.
Based on the above pdf I would assume ZZFR should work.0
ZZFR is not broken. It is working as designed. ZZFR is a command that is used when the radio is in split mode
You have to issue the ZZSW1 command first to place the radio into split mode. If there is not a slice B defined, one will be created. The issuing the ZZFR command will toggle the active slice between Slice A and Slice B until Split mode is turned off (ZZSW0)3 -
Thanks for the clarification Tim.
I am happy Sergey brought the up, I may use it in my Genovation keypad now that I know the details.
Tim thank you for clarification, learned that means armed !i suggest UM need a bit adopt to prevent misunderstandings
- 390 Community Topics
- 662 The Flea Market
- 440 SmartSDR for Mac
- 55 Aurora
- 971 Maestro
- 945 Genius Products
- 308 Shack Infrastructure
- 216 Networking
