ZZFR command malfunction
Sergey R5AU
Sergey R5AU Member ✭✭
edited August 2019 in SmartSDR for Windows
ZZFR cat command not  working as defined, but just toggle from active B to A (SSDR 2.0.17)
  • Clay N9IO
    Clay N9IO Member ✭✭✭
    edited August 2019
    Sergey is this what you are talking about?
    <macro><Button>TX Slice A</Button><Command>ZZSW0;</Command></macro>
    <macro><Button>TX Slice B</Button><Command>ZZSW1;</Command></macro>
  • Sergey R5AU
    edited August 2017
    Clay you are right , however ZZSW 0/1 need 2 dedicated macros instead one with ZZFR
  • Clay N9IO
    edited August 2017
    Sorry Sergey not familiar with that command.
    Only thing I could find on it lends me to believe it was from PowerSDR, maybe not compatible with SSDR?
  • Sergey R5AU
    edited August 2017
    Clay, I follow with SSDR CAT UM http://www.flexradio.com/downloads/smartsdr-cat-user-guide-pdf/ chapter 4.1 , both commands are presented and I appreciate to use single button on my external keypad to toggle between  A/B. On the fact you can just once switch active from B to A and no more else.
  • Clay N9IO
    edited August 2017
    Based on the above pdf I would assume ZZFR should work.
    edited August 2019
    ZZFR is not broken.  It is working as designed.  ZZFR is a command that is used when the radio is in split mode
    You have to issue the ZZSW1 command first to place the radio into split mode.  If there is not a slice B defined, one will be created.  The issuing the ZZFR command will toggle the active slice between Slice A and Slice B until Split mode is turned off (ZZSW0)
  • Clay N9IO
    edited August 2017
    Thanks for the clarification Tim.
    I am happy Sergey brought the up, I may use it in my Genovation keypad now that I know the details.
  • Sergey R5AU
    edited August 2017
    Tim thank you for clarification, learned that means armed !i suggest UM need a bit adopt to prevent misunderstandings
