How do I change my SmartLink account password?
Mark WS7M
Mark WS7M Member ✭✭
I cannot find a link or button to allow me to change my SmartLink password.  What am I missing?
  • Steve K9ZW
    Steve K9ZW Member ✭✭✭
    edited August 2017
    Lost password routine? Think that might work. 73 Steve K9ZW
  • Michael - N5TGL
    Michael - N5TGL Member ✭✭
    edited October 2019
    I wish it had a guest login that could be activated so you could share the radio if you wanted.
  • Mark WS7M
    Mark WS7M Member ✭✭
    edited October 2019
    Agreed on the guest login.  Maybe in the future.
    I posted it would be nice to have an "admin" regular login where you can do anything and a guest login where you could control a few things.  I mean for starters as a guest login I'd like to:
    1) Limit bands the guest can operate
    2) Limit max power
    3) Disallow any setup changes (network etc)
    That would make it nice and more secure for guest use.
  • Michael Aust
    Michael Aust Member ✭✭
    edited July 2017
    Yes, I agree after playing with V2.0 for a while an letting my friend test drive v2.0 with my station, he manage to unregister it and had to fix things.
    mike
    See Kenwood & Icom have both Client & Server of their software where V2.0 can
    be dangerous in the hands of a guest by messing up the setup to the radio !
  • Michael Aust
    edited July 2017
    Also, notice that a sequence in resetting had to done to restore
    SmartLink
    1. Router only on, forward TCP & UDP ports on Router
    2.) Next with UPnP enable on Router
    3.) Turn on Flex6xxx connected to PC thru Ethernet
    4.) Register Radio with PTT
    5.) Enable Smartlink UPNP ports
    6.) Make sure Green Light on Smartlink under TEST is green
         for both Automatic UPnP ports & Manual Forward Ports
    7.) Test V2.0.17 with LAN & WAN(outside)
    8.) Good to go !!!
    9.) If a guest login later, things get messed up since the guest can Unregister the
         Flex6xxx and since he has no access to PTT register, system fails
    10.) Repeat sequence above starting with everything off except router !!!
         Begin process steps  from above !!
  • Tim - W4TME
    edited August 2017
    That is the answer.
  • Dave - W6OVP
    Dave - W6OVP Member ✭✭
    edited June 2020
    I do not have a lost password.
    I want to CHANGE the password after the remote feature was tried by a friend who is a potential FLEX customer.
    Unless something has changed recently it seems WAY TOO COMPLICATED to simply change the password. It is keeping me from allowing others far away to try out my FLEX.
  • Patrick
    Patrick Member ✭✭✭
    edited October 2019
    Lost password has same effect as a dedicated routine....
  • Bob
    Bob Member ✭✭
    How do I please change my password?
  • K1UO Larry
    K1UO Larry Member ✭✭✭
    Unregister Smartlink from your radio and reregister with your new password.
