Adjusting waterfall height
Today it cannot be adjusted.
Mack
W4AX
Alpha Team0 -
Mack is correct. It is a fixed display size.0
Is there any update on the ability to reduce the height of the waterfall on the Maestro / 6600M?
They are still fixed height.0
OK Tim,
Thanks for the update. Please announce it when it is ready.
Geoff-W8GNM
This would be a nice feature. +10
Did adjustable height of the water fall window ever get added to the 6600M front panel?
Yes, there are two arrows ^v on the display that you can touch to raise or lower the spectrum line.
James, thanks for your reply. The ^ and v arrows along the left side of my spectrum display on the 6600M front panel adjust the dB scale per division on the spectrum display, but I still can't find a way to expand the height of the spectrum window and reduce the height of the waterfall window below it. I am running v 2.7.6 software on the front panel of the 6600M. 73, Geoff
Ok, I misunderstood your question. As for changing the display area size on the M model radios and the Maestro, you can't. Those are fixed.
- 107 SmartSDR+
- 427 SmartSDR for Mac
- 942 Maestro
