Adjusting waterfall height
KF4HR
KF4HR Member ✭✭
edited March 2019 in Maestro
Perhaps I've missed this in the manual, but when viewing one slice on the Maestro, is there a way to lessen the height of the waterfall display thus increasing the height of the spectrum display?  Or are these two sections of the Maestro display fixed ~50/50?
  • Mack
    Mack Member ✭✭✭
    edited March 2019
    Today it cannot be adjusted.
    Mack
    W4AX
    Alpha Team
    edited July 2017
    Mack is correct.  It is a fixed display size.
  • Geoff_W8GNM
    Geoff_W8GNM Member ✭✭
    edited November 2018
    Is there any update on the ability to reduce the height of the waterfall on the Maestro / 6600M?
    edited February 2018
    They are still fixed height.
  • Geoff_W8GNM
    OK Tim,
    Thanks for the update.  Please announce it when it is ready.
    Geoff-W8GNM
  • Jim
    Jim Member
    edited July 2018
    This would be a nice feature. +1
  • Geoff_W8GNM
    Did adjustable height of the water fall window ever get added to the 6600M front panel?
  • Trucker
    Trucker Member ✭✭✭✭
    Yes, there are two arrows ^v on the display that you can touch to raise or lower the spectrum line.
  • Geoff_W8GNM
    James, thanks for your reply. The ^ and v arrows along the left side of my spectrum display on the 6600M front panel adjust the dB scale per division on the spectrum display, but I still can't find a way to expand the height of the spectrum window and reduce the height of the waterfall window below it. I am running v 2.7.6 software on the front panel of the 6600M. 73, Geoff
  • Trucker
    Trucker Member ✭✭✭✭
    Ok, I misunderstood your question. As for changing the display area size on the M model radios and the Maestro, you can't. Those are fixed.
