No sound from remote PC SSDR 2.0
1. Make sure your remote key is depressed and is showing blue.
2. Right click on the speaker icon of your computer and select playback devices.
3. Select a listed playback device you know is working and set it as the default device.
4. Leave that window and , again, right click on the speaker icon and select "open volume mixer." You should see the SmartSDR as a possible selection. You should see the audio bar moving up and down with the audio. Be sure it is enabled to listen.
Thank you for the quick response. I neglected to engage the "REMOTE" button on the SSDR screen. I have a laptop that's connected to my home network in a different room than the shack and have to engage the remote button when operating there. I figured that I overlooked something lol. Thanks again Jim.0
Glad it helped. I had a similar issue in that I could not get Verizon to work. It turned out that I had not registered my iPad after loading Version 2. Some one jumped in and made me aware of the possible mistake. It is such a great group helping out each other.
Jim, K6QE
You will also need to check that your laptop's microphone is set as default in the Recording" tab or you won't be able to select "PC" in the SSDR mic tab.0
- 391 Community Topics
- 665 The Flea Market
- 165 SmartSDR+
- 446 SmartSDR for Mac
- 208 DAX
- 387 SmartSDR API
- 65 Aurora
- 304 FLEX-8000 Signature Series
- 978 Maestro
- 868 FLEX Series (Legacy) Radios
- 951 Genius Products
- 348 Tuner Genius XL
- 129 Antenna Genius
- 308 Shack Infrastructure
- 216 Networking
- 826 Peripherals & Station Integration
- 145 Amateur Radio Interests
