Smartlink on Carrier data networks
edited October 2019 in FLEX-6000 Signature Series
I have found that I cannot use Smartlink on my iPhone using Version LTE. When I try to discover the radio nothing happens. When I switch to a WiFi network the Flex 6500 is easily discoverable. If I connect to my remote site using L2TP VPN I immediately see the radio and can connect, which would be expected. Is it a known issue that one, as yet, cannot use carrier networks but only WiFi?
Welcome!
  • Member
    edited July 2017
    Try to put your radios IP address in there. In the settings put it on Fixed. and see if it works.
  • Member
    edited July 2017
    Have you activated Smartlink in settings in SmartSDR on your Iphone?  I am using Verizon LTE with my Jetpack and it works great. My radio is a 6500.  I have also connected via Smartlink over Verizon using my Ipad or my IPhone 7.
    You also may want to be sure you are not accessing your local LAN on wifi versus using Verizon.  If your local LAN is connected via WIFI,  SmartSDR uses it instead of Smartlink.
  • Member ✭✭
    edited July 2017
    Everything works perfectly remotely using WiFi. I disable my WiFi and enable the data network on my iPhone and works as described above. I am glad it works for you. I must be doing something wrong but just can't see it. Thank you very much for your response, Atimus.
  • Member ✭✭
    edited July 2017
    Got working! **** me, I didn't register my iPhone for Smartlink. thank you so much for your help. This is a great group to be part of!
    Jim, K6QE
  • Member ✭✭
    edited October 2019
    It seems AT&T network is slower then Verizon. More stuttering on AT&T using IPad sitting on runway waiting for clearance from weather. Seems likes working Mike N9DFD
