Smartlink on Carrier data networks
Try to put your radios IP address in there. In the settings put it on Fixed. and see if it works.0
Have you activated Smartlink in settings in SmartSDR on your Iphone? I am using Verizon LTE with my Jetpack and it works great. My radio is a 6500. I have also connected via Smartlink over Verizon using my Ipad or my IPhone 7.
You also may want to be sure you are not accessing your local LAN on wifi versus using Verizon. If your local LAN is connected via WIFI, SmartSDR uses it instead of Smartlink.0 -
Everything works perfectly remotely using WiFi. I disable my WiFi and enable the data network on my iPhone and works as described above. I am glad it works for you. I must be doing something wrong but just can't see it. Thank you very much for your response, Atimus.0
Got working! **** me, I didn't register my iPhone for Smartlink. thank you so much for your help. This is a great group to be part of!
Jim, K6QE
It seems AT&T network is slower then Verizon. More stuttering on AT&T using IPad sitting on runway waiting for clearance from weather. Seems likes working Mike N9DFD0
- 417 Community Topics
- 716 The Flea Market
- 224 SmartSDR+
- 471 SmartSDR for Mac
- 270 SmartSDR CAT
- 225 DAX
- 397 SmartSDR API
- 140 Aurora
- 1K Genius Products
- 366 Tuner Genius XL
- 139 Antenna Genius
- 333 Shack Infrastructure
- 237 Networking
- 149 Contesting
