Setting up for SmartLink
I've been reading all the posts and manuals about Smartlink and have two Qs.
1) Enabling uPNP on the router will allow Maestro, by way of example, to setup the required port forwarding. Once these are setup can one turn off the uPNP feature and the ports will stay open? I assume one can look at the routers 'home pages' and see which ports have been opened.
2). When signing up for the SmartLink account, one has the option of using a Google / FaceBook account. For the initial sign-in in will F/G work?
If 1 == T then use that method
else manual port forwarding
BTW in studying the router here, I discovered it can block domains. Added the 'ad domains' and internet traffic is way down. It seems sites don't know they're ad-blocked.
Thanks for any expert advise.
k3Tim / 6
k3Tim / 6
The router will need uPNP or. Anual port forwarding done to forward to the radio, not Maestro. You will need to leave uPNP enabled for the radio to register with the SmartLink server and accept connections from your client over WAN (SSDR, Maestro or SmartSDR for IOS). Using the Maestro away from the radio (WAN) does not require uPNP or manual port forwarding for the Maestro network. You can use either your Facebook login, Google login, or use an email address when you create the SmartLink account. If you are logged into SmartLink and close SmartSDR it will log you on the SmartLink server next time you open SmartSDR. You do not need to log out of SmartLink. I did a video of the Radio upgrade and SmartLink registration that should be poated later today so you can see how easy it is. Dave wo2x3
Dave : Thanks for the detailed reply. I think that covers it and should be all set here. Will have a look at the video when posted.
Thanks for your help.
Best,
Tim
Note that if you do decide to use a social login, you can enable two factor authentication. This provides additional security.
Ria0
- 395 Community Topics
- 674 The Flea Market
- 187 SmartSDR+
- 192 SmartSDR for Maestro and M models
- 454 SmartSDR for Mac
- 276 SmartSDR for iOS
- 216 DAX
- 389 SmartSDR API
- 87 Aurora
- 325 FLEX-8000 Signature Series
- 983 Maestro
- 959 Genius Products
- 351 Tuner Genius XL
- 131 Antenna Genius
- 313 Shack Infrastructure
- 218 Networking
- 836 Peripherals & Station Integration
- 146 Amateur Radio Interests
