Tuner Genius power supply
Ned K1NJ
What are the power requirements for the Tuner Genius?
Ned, K1NJ
Hello Ned,
While not completely sure, I think I saw a note somewhere that the turner will be powered by coax from PG.
Looks as a neat solution
TBD, but I wouldn't be surprised if it's 12V DC like pretty much every other accessory, including nearly every auto tuner ever made.0
Thanks for replies. I strongly suspect 12 Volts D.C., just not certain. Probably fed via
coax when the control-over-coax feature is added. I'm planning on placing it at the antenna
soon after testing, which would mean that I'd have to add a 12v. supply that I can shelter from the
elements. I have 115V A.C. at the antenna. I also wonder about the weather proofing of
the unit itself. It has been said that it was designed with at-the-antenna placement in mind.
But, weather proofing can be tricky.
I guess my anticipation anxiety is bubbling up a bit.
Ned, K1NJ
@Ned. Most of the Genius lines use nominal 12v DC and along the way an injector was mention/shown to extend for remote locations. All of this may be subject to 4o3a's final revision and I'd not get too worried about planning it until we're shown a close to production prototype. All best and 73 Steve K9ZW0
Right you are, Steve.
Ned, K1NJ
- 379 Community Topics
- 636 The Flea Market
- 140 SmartSDR+
- 260 SmartSDR CAT
- 199 DAX
- 44 Aurora
- 271 FLEX-8000 Signature Series
- 956 Maestro
- 57 FlexControl
- 301 Shack Infrastructure
