“Flex Radio Systems FlexVSP” is corrupted every time Lenovo and CAT are booted.
Stanley Korzep
I am using a 6300, Maestro, 1.10.16, with Lenovo WIN7 to provide DAX and CAT functions for Fldigi and N1MM+.
Tim's solution works but is annoying to use every day.
Can anyone help me resolve this daily corruption problem?
Stan W8NNX.
Stan W8NNX.
On the surface, this sounds like a permissions problem or there is an installed program that is preventing the FlexVSP service and the DAX drivers from loading properly, like preventing Registry access.1
Good morning Tim. The hard drive was wiped clean before installing it in the Lenovo (used, came without drive) Only programs on it are SmartSDR, Fldigi, N1MM, and Google. I don't have a PC background: I need a bit more help please. Stan
Hi Stanley What is the error message?0
Stan,
I wish it was possible that I could be more helpful for this particular situation, but dealing with individual's PC operating system issues is a little out of scope for the support we provide at FlexRadio. If you are not able to get a successful remedy from the users on the Community, let me know and I'll get you in touch with someone who does remote operating system support that is a long time Flex user.0 -
Hi Michael. No error message. Problem evidenced by frequency reading on upper left corner of Fldigi reading inaccurate and not changing as the actual frequency changes.
Tim has me on the right track.. I originally wanted to do a bit of brain exercise by incorporating Fldigi into the station. In one day and his comment, I have learned a lot. I think I have the solution operating now. If all goes well in the next day, I will share his guidance and the solution with all. In the meantime, as my kids would say,"Tim,You De Man".
73 Stan W8NNX
Hi All. Tim's guidance led me to removing the external virus protection and the external firewall, one at a time. The firewall was causing most of my corruption problem. The virus protection had no effect. Part of the explanation I believe is that WIN7 Pro appears to not turn off "defender" when external protection is in place. I had two firewalls running simultaneously...probably not a recommended configuration.
I have only the WIN7 programs plus SDR, Fldigi, and N1MM+ programs now on the Lenovo. I can not correlate any other activity to the random corruption.
One other clue I have found: if all is running well and I get brave and try to connect to the N1MM telnet mode, I not only experience the instant corruption; the Lenovo suffers some problem that can only be cured thus far with a reboot.
Anyone out there have an idea?
Stan W8NNX
Follow-up for Tim: I have learned a lot about com ports since your last response. I have the digital programs FLDIGI, N1MM+, the WSJT-X, and WSPR programs working very nicely, but I am still troubled with the need to repair the VSP each time I power up.
I have interpreted your initial diagnosis as having a problem with conflicts in the com ports. Indeed you were correct; I did have a couple. Now that everything seems to be functioning as I would expect, I have ended up with just the one continuing problem.
I have removed one program at a time until all programs have been eliminated by closing the port that they connect to. I am down to only one port shown as Com1. This includes "ghost ports". I have removed the input to the Com1 connector.
My final test was to power up the Lenovo : no power to the 6000 and the Maestro. That condition has only the 1.10.16 SDR, DAX, and CAT.operational, but leaving the other digital programs no port to talk with.
The final test was to exit CAT to repair the VSP, verify that the VSP was repaired, check the lack of existing ports except for Com1, and restart CAT. Then I exited CAT and checked the VSP that now show failed mode,. I verified that there was still only Com1 present...no ghosts.
Can you hint where I have gone wrong?
Stan
The VSP port configuration is stored in 2 places; the registry and the CAT.settings file that resides in the %APPDATA%FlexRadio Systems folder. If created ports are not being saved, I suspect it is a permissions problem (not enough rights to write data to those locations or a security program is preventing it from happening). Unfortunately, this seems to be an issue unique to your PC and that is going to make it really challenging to figure out what is happening.
At this juncture, I'd recommend opening a HelpDesk support ticket to see if we can figure out a way to make the driver install and run properly.
- 246 Community Topics
- 488 The Flea Market
- 7.3K Software
- 328 SmartSDR for Mac
- 241 SmartSDR for iOS
- 224 SmartSDR CAT
- 161 DAX
- 343 SmartSDR API
- 8.5K Radios and Accessories
- 768 Maestro
- 42 FlexControl
- 726 Genius Products
- 251 Tuner Genius XL
- 84 Antenna Genius
- 223 Shack Infrastructure
- 150 Networking
- 118 Contesting
- 116 Amateur Radio Interests
- 810 Third-Party Software
