Flex 6500 6 meter receive improvements in V2 software?
KA9CFD
I would like to know if there will be any receiver improvements for the Flex 6500 in the version 2 software. Specifically receive sensitivity for 6 meters.
Jay KA9CFD
Jay KA9CFD
Me too!, but I don't think it's software...(;(
Wow, ... I'm very envious if your location is quiet enough on 6 meters to possibly notice better sensitivity.
Put a 50-Ohm load on the rx loop input corresponding to the same antenna as you have for 6 meters, then alternately select the antenna or the dummy load. If you can see 6 or 7 dB of "antenna noise", you'll be hard pressed to notice any real-world improvement from lower noise figure.
If you can see 10-13 dB (or more) of "antenna noise", it's theoretically impossible to notice the faintest difference.
Do the experiment and tell us what happened.0 -
and it's better to put a preamp close to your yagi, then you compensate for all the coax loss0
A pre-amp only works if there is a real reason to employ one. If one is using the +30 dB built-in pre-amp gain setting on 6 meters, there is only the very slimmest chance that an external pre-amp is actually useful. If one refuses to do the antenna-vs-50-Ohm-load comparison, one is giving in to superstition instead of science. YMMV. "Antenna noise" ratio to a 50-ohm termination is the only proper way to decide.
Superstition is a cruel master.0 -
Mike has a point. In all but a very small subset of locations, local noise will be the limiting factor for detecting weak signals. On 6 meters and below, the best results will come from reducing that local noise, rather than trying any more gain stages. Howard, KY6LA, presented a great tutorial on noise reduction some time back.
Let me tell you, aggressive noise reduction is the way to go. And by that I mean dealing with the sources directly. Noise blankers and such are good (sometimes very good) tools, but nothing compares to shutting down the sources. You'll gain far more S/N that way.
Above 6m, Wim is spot on about the preamp at the antenna. Even there, though, you may need to take aggressive steps on source noise reduction, or the extra gain is for naught. Each installation will be different.
Good luck!0 -
The Flex 6500 built in preamp is 20 db, not 30 like the 6700. And it is a must use otherwise the radio would be deaf. I have worked 52 EU contacts in the log for this sporadic e season, all of it digital.0
In V2.0 the Flex 6700 Preamp is upgraded in software to +40dB so that is a definite improvement for 6M1
The above link is toy aper on noise mitigation0
The answer to the original question, is there are no specific program changes specific to 6m improvements on 6m.1
- 328 Community Topics
- 594 The Flea Market
- 7.8K Software
- 6.2K SmartSDR for Windows
- 397 SmartSDR for Mac
- 260 SmartSDR for iOS
- 247 SmartSDR CAT
- 179 DAX
- 369 SmartSDR API
- 9.1K Radios and Accessories
- 15 Aurora
- 162 FLEX-8000 Signature Series
- 909 Maestro
- 51 FlexControl
- 873 Genius Products
- 312 Tuner Genius XL
- 115 Antenna Genius
- 278 Shack Infrastructure
- 196 Networking
- 135 Contesting
- 726 Peripherals & Station Integration
- 136 Amateur Radio Interests
- 945 Third-Party Software
