Will SmartSDR 2 be Morse Code Compatible
Bill / VA3QB
With the release of smartSDR 2 , will a user on a computer/laptop in remote mode be able to use Morse Code ? At present it only works directly into the Flex radio or on the Maestro.
Bill
VA3QB
Bill
VA3QB
Only with CWX including Winkey emulation. You can't plug a set of paddles in remotely without an external box. So, same as 1.x.0
CWX is great but the possibility of connecting a key would probably be an option appreciated by many telegraphists.
I was hoping that a solution would be found with SmartSDR 2 :-(
Please, Ria, when you talk about "external box", what are you referring to?
Is there a solution today that is not a gas plant and working properly?
Thanks for your advices…
73, Jean-Luc / F5JRC0 -
External box meaning third party solution.
Actually I believe if you use the maestro it will work too since it has its own winkeyer.0 -
thanks Ria... that was the question I was just going to ask. We have a camp on a lake a few miles away and I have been dreaming of sitting over there with the Maestro watching the world go by and playing with the Maestro. Mike W1BFA
Thanks Ria, it would be interesting to have a feedback from the owners of Maestro for this feature...
I'll try with my Maestro ,but truthfully it hasn't really left my shack... I use my iPad.0
One 3rd-party option uses a pair of inexpensive WinkeyerUSB devices on each end of the link. The controlling software runs on a PC in server/client mode using K1EL's WK-Remote software, I've been using the K1EL remote system for almost a decade with other transceivers and it works very well with excellent CW timing/spacing.
http://k1el.tripod.com/WKremoteX.html
Like the Maestro**, the WinkeyerUSB uses a square-wave side-tone generator. I first modified mine with a sinewave "Twin-T" oscillator and voltage-controlled amplifier (VCA) that ramped the CW sidetone just like a transceiver. The second (and current) iteration uses N4YG's DSP chip that digitally produces a ramped sinewave.
Because of the CW side-tone, issue, my Maestro has not seen much use. CW enthusiasts who plan on using a Maestro over the Internet should be aware of this limitation.
Paul, W9AC
** The Maestro's CW side-tone comes from a built-in WK and hence, the reason for the square-wave side-tone. Well, it's really a quasi-square wave as its been filtered by Flex but the end result still sounds much like a square wave.
Thank you very much Paul for these informations, it is very informative.
So I see that it's not so simple, the changes you've made unfortunately exceed my skills.
I thought about buying a Maestro, but suddenly I'm no longer sure of my purchase. I would like to know the official position of Flex on this subject...
The official position is that we will have to do a fair amount of software work to fix the K1EL WinKey sidetone through reconstitution of the sine wave. This is in the backlog but not yet scheduled (no date yet). It does sound better than a native WinKey output though.0
Winkeyer works with SmartLink on Maestro. That is your only turnkey solution if you want a traditional morse experience.0
Thank you Rya, I wait a little to see if can test with an OM not too far having a Maestro…
Thanks Gerald, as I said to Rya, I wait a little to see if can test with an OM not too far having a Maestro... and this sidetone "issue" is perhaps not really one for me!
It's ria Don't poke out my i
Sri, :-)0
- 110 SmartSDR+
- 257 SmartSDR CAT
- 943 Maestro
