Adjust stream range SDR Bridge /SmartSDR ?
Andrew O'Brien
Member ✭✭✭
During Field Day I had SmartSDR and SDRbridge working well on 20M. However when I switched bands the range of the stream referenced in SDRbridge was not within the desired range . Example the stream was 7050 to 7150 (or thereabouts ) but I wanted to skim a range from 7000 to 7096 approximately. Same happened on 10 and 15 . So how does one change the range ? I tried simply clicking on a lower frequency in SmartSDR , SmartSDR moved but not the range of the stream in SDRbridge. Andy K3UK
I use the up down buttons in skimmer starting at the bottom of the band and click to the top to fill in skimmer and then use that data to fill in the n1mm band map. 73 W9OY0
Change the width and center frequency of the panadapter.2
- 650 The Flea Market
- 151 SmartSDR+
- 263 SmartSDR CAT
- 48 Aurora
- 964 Maestro
- 936 Genius Products
- 343 Tuner Genius XL
