Receive problem
Well I never,reduced nb to zero and everything ok,so much for the flex nb0
Hope flex are aware of this problem0
Sorry agc set at medium0
Turning the nb off seems to solve the problem0
@ Tony - Isn't default NB off and the slider default Zero? It has to have a wide range of settings to accommodate all users.
If you don't hear things the way you expect your always doing good sleuthing to undo the recent settings changes.
https://k9zw.wordpress.com/2008/12/16/repost-snap-snap-photographing-your-shack-setup/ (which should be updated to include the use of cell phone cameras and screen snips) reflects the idea that when things work, mark-down/record/photograph ALL the settings that got you there.
That becomes a sort of "home spot" you can then get back to.
Profiles help, but I still do screen shots myself. YMMV, but it sure does save from the embarrassment of asking for help over a self-inflicted settings change.
Glad you are back in a good place,
Steve K9ZW
- 245 Community Topics
- 490 The Flea Market
- 7.4K Software
- 327 SmartSDR for Mac
- 243 SmartSDR for iOS
- 224 SmartSDR CAT
- 163 DAX
- 347 SmartSDR API
- 8.5K Radios and Accessories
- 766 Maestro
- 42 FlexControl
- 727 Genius Products
- 251 Tuner Genius XL
- 84 Antenna Genius
- 222 Shack Infrastructure
- 149 Networking
- 118 Contesting
- 116 Amateur Radio Interests
- 809 Third-Party Software
