Need help with SSDR and CWskimmer de k1dw
Dallas k1dw
There is a problem with my CW Skimmer, DAX Control and SmartSDR. All the CAT connections seem to work. However the DAX I/Q signals into CW skimmer does not line up with the SSDR slice. According to the DAX instructions the DAX center frequency determines the center frequency of the I/Q path to the CW Skimmer.
Maybe a demo via Teamviewer would be a better way to explain my problem. If you can help, contact me off line at K1DW@aol.com
Hi Dallas,
The centre frequency of the panadapter is the centre frequency on skimmer. There is also an issue of resolution. CW skimmer via SDR-bridge uses telnet commands and this only gives you 0.1kHz of resolution.
But if you're having larger discrepancies than that I'd like to see.
Ria0 -
I seem to always have this same issue. Part of it for me is screen resolution as well. Since CW skimmer paints vertically and my monitors are more wide and vertical I often cannot see the full Dax I/Q vertically. So things are always off for me. IE to get my slice to be centered in my height impaired skimmer window I have to have my slide down near the bottom 1/3 of my pan adapter.
I have in the past turned one monitor vertical then I get better results.0 -
Thanks for the help and direction to try SDRBridge. I had tried it before but no luck. It worked this time, super great. The quick answers really did the trick.. TNX agn . 73 de Dallas k1DW
I see all the compatibility issues haven't been worked out yet... Good to know.. I will wait for a couple of iterations before I spend the 75 dollars on cw skimmer I came close this past weekend0
At this point I would wait. Alex is working on a brand new version. However I really don't have any issues.0
- 657 The Flea Market
- 438 SmartSDR for Mac
- 385 SmartSDR API
- 52 Aurora
- 295 FLEX-8000 Signature Series
- 969 Maestro
- 943 Genius Products
