Help Fldigi problem
Takeshi Yamada
I re-installed Fldigi, but I cannot transmit.
CAT is working. DAX seemingly is working. level indicator shows a good level of input, but there is no RF signal.
WSJT-X works fine, so it must be my **** setting mistake, but I cannot find out the cause.
Use "Line" instead of "PC" in your output settings and try again.
I saved all my settings in a digimode profile.
Good luck!
73, Alex - DH2ID0 -
Thank you for your help, but it does not solve the problem.
Very strange...
One basic question.
I am not clear about the differences of LINE and PC when using digital software like Fldigi, wsjt-x, mmtty.
I tried with WSJT-X, but both LINE and PC looks giving the same RF output.
73 de JI1BNU
Ken Yamada
Ken,
I have a 6500 and after this months Windows update my DAX failed. The cure for me was to remove and reinstall SSDR. Don't forget to export your settings before removing SSDR.
Roy W5TKZ0 -
Yamada-san,
It looks like you're in RTTY mode in Fldigi and on the Flex. Fldigi doesn't key FSK, only AFSK. Try putting the Flex in DIG-U mode and see what happens.
Dave
K3DCW0 -
Bingo!
It was my mistake. I ran MMTTY setup and Fldigi setup and I was messed up.
By setting mode to "DGMU" it was solved.
Thank you Dave and sorry for bothering you all...
73 de JI1BNU
Ken Yamada
I'm glad you got it working.
730
- 390 Community Topics
- 662 The Flea Market
- 440 SmartSDR for Mac
- 55 Aurora
- 971 Maestro
- 945 Genius Products
- 308 Shack Infrastructure
- 216 Networking
