Help Fldigi problem
Takeshi Yamada
edited December 2019 in FLEX-6000 Signature Series
I re-installed Fldigi, but I cannot transmit.
CAT is working.  DAX seemingly is working.  level indicator shows a good level of input, but there is no RF signal.
WSJT-X works fine, so it must be my **** setting mistake, but I cannot find out the cause.image
  • DH2ID
    DH2ID ✭✭✭
    edited June 2017
    Use "Line" instead of "PC" in your output settings and try again.
    I saved all my settings in a digimode profile.
    Good luck!
    73, Alex - DH2ID
  • Takeshi Yamada
    edited June 2017
    Thank you for your help, but it does not solve the problem.
    Very strange...
    One basic question.
    I am not clear about the differences of LINE and PC when using digital software like Fldigi, wsjt-x, mmtty.
    I tried with WSJT-X, but both LINE and PC looks giving the same RF output.
    73 de JI1BNU
    Ken Yamada
  • RoyS
    RoyS ✭✭
    Ken,
    I have a 6500 and after this months Windows update my DAX failed. The cure for me was to remove and reinstall SSDR. Don't forget to export your settings before removing SSDR.
    Roy W5TKZ
  • K3DCW
    K3DCW ✭✭
    edited April 2019
    Yamada-san,
    It looks like you're in RTTY mode in Fldigi and on the Flex.  Fldigi doesn't key FSK, only AFSK.  Try putting the Flex in DIG-U mode and see what happens.
    Dave
    K3DCW
  • Takeshi Yamada
    edited June 2017
    Bingo!
    It was my mistake.   I ran MMTTY setup and Fldigi setup and I was messed up.
    By setting  mode to "DGMU" it was solved.
    Thank you Dave and sorry for bothering you all...
    73 de JI1BNU
    Ken Yamada
  • K3DCW
    K3DCW ✭✭
    edited June 2017
    I'm glad you got it working.
