how do I remove the CAT com ports?
ON5AM
Hi,
That's very simple. I have ghost COM ports, when I chose a new port com, I can't how to go back and take my port Com 4, 5 etc ... I am now at COM port 23 and the more I advance the number go up. I deleted all my COM ports but they come back when I reset the PC.
What to I do. Have you a solution?
Tks for help me
Tks for help me
https://helpdesk.flexradio.com/hc/en-us/articles/200883925?mobile_site=true This should help Dave wo2x1
Thanks Dave for the info, I needed that....Rick, kd4dra
First thanks.
David, unfortunately I applied this method but the result at home did not bring anything. After some time I have all my COM port just like pictures.
I don't know what I do now ?
You can try try using a program Tim recommends called Com Name Arbiter Setter
http://www.uwe-sieber.de/misc_tools_e.html#arbiter
This will allow you to clear com ports that are incorrectly set to reserved in the Windows Registry.
Dave wo2x0 -
I will try and keep you informed
Hi,
Now everything is good and I'm happy :-)
I delete all COM port in Device Management after I uninstall the FlexRadio System FlexVSP oh yes...uninstall
I Restart 2 times and after will be OK.
Now I have the Ghost COM port 4, 5, ...
Thanks for your help.
Al
There is a MUCH easier way. Open SmartSDR CAT, right click on the Remove button and select the option "Reset FlexVSP ports".1
Thanks you Tim
Tim, I'm sorry but i don't see "reset FlexVSP ports". I have V1.9.13
Can you help me ?
Upgrade to the latest version of SmartSDR, 1.10.16.0
Thanks, right click on Remove works but is non-obvious to find. Could you add 'Right-click for removal options' to the hint text for the button ?0
It's obvious if you read the CAT documentation ;-)
We'll take your suggestion under consideration.1 -
"this may take a while " means ???
- 393 Community Topics
- 668 The Flea Market
- 174 SmartSDR+
- 450 SmartSDR for Mac
- 276 SmartSDR for iOS
- 266 SmartSDR CAT
- 215 DAX
- 389 SmartSDR API
- 70 Aurora
- 981 Maestro
- 952 Genius Products
- 349 Tuner Genius XL
- 129 Antenna Genius
- 311 Shack Infrastructure
- 217 Networking
- 146 Amateur Radio Interests
