Input wanted on new 6600M
WV9L
Before i trade my 6500 off toward a 6600 or 6600M...... I mostly operate via my ipad or iphone 7+. Only time i use the pc, is when i remote into it to do jt65 or other digi modes. So, with that said, what would be the reasons or advantages to upgrade from the 6500 to a 6600? I have talked to a fellow ham about putting my rig at his station and sharing it as he would then be able to operate remotely as well. He has a quieter location and more realestate. So, my next question is more geared to v2.0. If we did put either my existing 6500 or a new 6600 at the location, say i was connected via my apple device thru the app. If he was at the location, could he also be connected at the same time, via the pc or the front control head(if it were a 6600M)? I know we cant both talk at same time. Just trying to understand all the options and make an educated decision.
What you are asking for is MULTI client
On the TO DO LIST but not implemented yet
Flex will not give you an ETA0 -
From what I can gather from your operation, not much to be gained upgrading. Unless the contest band filters and second SCU are something you think you’d use, you will be pretty happy with the 6500. The 2nd SCU will come in handy for the way I operate at home, including keeping an eye on 6m when running elsewhere, doing satellite work, etc. Like you, a lot of my operating is remote, and for that purpose, I think it would be hard for me to wrangle two slices, no less anything more. If ease of general remote operating was my main criterion, I’d stick with my trusty 6500 running version 2.x. I —think— you will be able to listen to one SCU while your buddy is on the other (with the 6600) in the future. Don’t think it will be part of the 2.0 release, though. Hope that helps!1
From what I've seen so far the only advantages of moving from a 6500 to a 6600 seem to be:
* two transverter inputs
* 7th order filters on the HF Contest Bands (3rd order on the other bands)
* a HDMI port
* Antenna Diversity function
And the 6600M adds the non-removable Maestro display.
Thanks!!0
Since the 6600/M will only display 2 slices/panadapters, can a computer be connect to the radio to see all 4 slices/panadapters, or will Multi Client be required?
Thanks! Yeah i think the filters would be nice, but think im better off keeping what i have.0
Clarification - HDMI port is only on the -M versions.0
Hdmi would be nice, but my pc has that, so no real gain. All i could really see was the filtering. But, not a huge change. I guess ill stick with my 6500. Was just trying to see. I got an offer from then on the trade amount. Was very reasonable. But i wanted to see if i should do it, or just spend the $200 and get 2.0 on my 6500 when it comes out.0
Great question about the advantages. IMHO, any Flex Signature rig is better than most other HF radios out there and all the angst about selling an old model line to get one from the new model line seems like trying to get the last drop of performance possible i.e. "blood from a rock". I can see moving from a 6300 to anything higher (old or new models) for the improved dynamic range, but other than that, these are all great radios. Maybe I'm wrong, it happens.1
TBD0
The 6600M gives you the ability to perform like an IC-7610, that is, no PC required, with knobs and buttons on its front panel! OTOH, you still have full remote control. Everything to gain, and nothing to lose.
Br,
Larry
WA7LZO
Im operating remote, so the display makes no diff to me. Have to have pc for the digi modes anyways. Save a $1K towards other toys!!0
I bet once you start actually using that 6600M with its beautiful Dell tablet hi res display, you will absolutely love it, and not want to be without it. And, don't forget those awesome knobs and buttons, too! It may just look so darn good, you will change your mind about being remote 100% of the time. Then again, your Ham friend may not let you borrow it!0
Im never at the radio end. So waste of $1k. Like buying a snow blower in Miami.1
Watch it snow in Miami this week LOL0
Once you see how cool that new 6600M is, you won't want to be without it! That front panel is smokin', bro!
I bet it snows in Miami IA :-D0
As i stated above, i work remotely. I never go to the transmitter location. So the pretty screen is worthless to me. I only use the pc hooked to the rig for digital modes. Then at that, im remoting into it from my ipad. So im compairing the 6600 to my 6500. The only way id consider an M model is if it would allow multiple users on it at once, which was stated above, as not possible at this time. If it would, id move it to a buddies QTH, and he could use the PC or the screen. But as for me i only use IOS. So it looks like il be keeping my 6500. Thanks for the info guys0
Then get a 6600. I didn't buy a maestro either.1
With the HDMI on the 6400/M and 6600/M, no computer is needed. That is huge for those not wanting to lug a computer along or have a computer in the shack. That is one of the real gains of the front panel.
Only thing i use pc for is digi modes snd softether. V2 will replace softether, but still need pc to run digi modes remotely. Again, i am never at the radio itself.0
Good to know0
Once you see that beautiful hi res screen on the 6600M, you'll change your mind! Don't forget when multi client comes along, you can operate at the station, while someone else is having remote fun. I bet you will decide to take that puppy home, once you see that screen, up close and personal :-)
When i bought my 6500 they said 2.0 would be out by end of march. So i sold my remoterigs and TS-480HX. Been very happy with rig. Ive managed to get by using softether as i only work remotely. Im not gonna buy a 6600M because "someday" there will be multi-op. Probably be a 7000 series by then. So, i think ill stick with what i have, till then. Thats the only reason i would do the 6600M. Cant see buying one on a pipedream, then seeing new models come along before it, much like 2.0 and my 6500. Just sayin. To each their own.0
ok..so help me understand 6600M capabilities...i understand that the 6600M will only display 2 slice/panadapter...OK about that even though the radio is capable of 4 slices.
So how do you get to see and use all four slices?
if i am assume by using ssdr v2.x on a PC you can see and use all four slices. So when in that mode of operation what is the display doing?
does it just go blank?
is it displaying first two slices?
does it have active control of the radio?
on the other hand not using a PC,
Can the display open 4 slices on the radio but for display purposes you can only rotate thru by displaying two slices at a time?
ow much of this is still TBD?
any info or insight is greatly appreciated
How much of this is still TBD?
At this point, a lot of it. We are still writing the software for it. As soon as we have something definitive to share, we will.0 -
Here's my opinion. Hope I don't ruffle too many feathers.
The all in one "box" radio concept, aka the M model is great for traditionalists. I mean, many people criticized Flex because "them dang radios ain't real radios if you have to use a 'puter!" Now they have their radio.
However my personal preference is a standalone "server" radio and a separate Maestro. For the same money I can take my Maestro radio console anywhere and I'm not tied to this big box on my desk. I can even centrally place the radios in a rack for a multi-op.
With SmartLink I can take it anywhere with me, across the world basically.
So that is my preference. Not to say the M models won't have its fans but I like the idea of a separate client and flexibility the maestro offers.
Ria6 -
Not only two transverter ports, but also two SCU's which would allow full duplex on two different antennas- SO2R capable, depending upon antenna isolation, or ability to monitor two widely divergent bands on different antennas, I.e. 160 and 6 meters at the same time......1
ok...thanks tim
I agree, the best feature of 6xxx series is they operate as a server and all that comes along with the ability of DAX/CAT interfaces for data manipulation and control. This combo allows for a wide rage of what i call 'ham radio assistants"...software such as cwskimmer, DDutil to name a few and the ability for wide range of digital modes.
In my shack, I run two mac mini computers with four monitors thru a KVM switch. one monitor with world map with grey line and cluster spots on it, another monitor with mldx logger with it cluster/ spot feature. still another monitor with the panadapter either using ssdr or dogparksdr and other monitor showing digital modes all connected to flex 6300. these are all ham radio assistants....my standard setup....
maximum information and situation awareness..
However, User Interfaces are extremely personal in nature. The M series does add the all-in-one feature plus it keeps everything else i currently have with a headless server.
My preference is for maximum flexibility. The more... the merrier.
What knobs do is add real tactile feel while tuning, and the utilization of muscle memory for quick tweek of volume to name a few advantages. Knobs engage the tactile sensor feedback, spatial awareness for quick response and your eyes and ears stay engaged on the target (oops ..signal of interest).
i have 6300 and will be upgrading to 6600M. I really like my 6300 but miss diversity reception and at times the quicker human in the loop response achieved with knobs and buttons. The two SCU's for using two transvertors for satellites and few other feature toos
i enjoy using my ipad and iphone to make cw contacts while sitting on the deck and enjoying a day outside. Sometime even quick check of the band using my laptop ( macbookpro). These remote modes of operating help me achieve 8 band dxcc...by being 'there' when the band opens.
a lot to be said for remote operations and a lot to be said for sitting face to face with the radio...
i enjoy it all...
once again...the more...the merrier0
- 378 Community Topics
- 116 SmartSDR+
- 37 Aurora
- 946 Maestro
- 923 Genius Products
