Option to load a Global Profile on SmartSDR start.
Active Slice is not handled by Persistence per Tim "This is the way the radio works." in response to my Ticket below. For that and lots of other reasons I think the best solution to provide an option to load a specific Global Profile when SmartSDR starts.
Response:
This is the way the radio works. Persistence takes precedence over profiles. Global profiles do not auto load when the radio is started.
Ticket #18262
When using 2 slices at the same time the Active Slice is NOT remembered across Exit/Start. My Global Profile has Slice A Active and TX on 20M and Slice B on 17M. When I Exit and then start SmartSDR it comes up with Slice A NOT Active and TX on 20M with Slice B Active and NOT TX on 17M - this isn't very helpful and I always have to load my Global Profile manually to get things back to Normal.
I suggest either 1) adding Active Slice to persistence or 2) providing an option for specifying a Global Profile to be loaded at Start. I definitely prefer #2.
BTW. I have verified this with FRStack and all other auxiliary software NOT running.Response:
That's true - that's the way it is. I think the problem is one of those things that some people want, and others don't. Regardless, it's not terribly difficult to do the two mouse clicks to load the global profile.
You should probably post it as an idea, not a problem ticket. Problem tickets are for fixing equipment and software problems when it doesn't act as designed. Ideas are for feature requests.0 -
Yes, I did Post the option on start as an Idea but I reported the problem as a bug because Persistence should be handling Active Slice just like it handles other Slice properties. But for now "that's the way it works".0
- 389 Community Topics
- 53 Aurora
- 971 Maestro
- 945 Genius Products
- 307 Shack Infrastructure
