Option to load a Global Profile on SmartSDR start.
Ticket #18262
When using 2 slices at the same time the Active Slice is NOT remembered across Exit/Start. My Global Profile has Slice A Active and TX on 20M and Slice B on 17M. When I Exit and then start SmartSDR it comes up with Slice A NOT Active and TX on 20M with Slice B Active and NOT TX on 17M - this isn't very helpful and I always have to load my Global Profile manually to get things back to Normal.
I suggest either 1) adding Active Slice to persistence or 2) providing an option for specifying a Global Profile to be loaded at Start. I definitely prefer #2.
BTW. I have verified this with FRStack and all other auxiliary software NOT running.Response:
This is the way the radio works. Persistence takes precedence over profiles. Global profiles do not auto load when the radio is started.
That's true - that's the way it is. I think the problem is one of those things that some people want, and others don't. Regardless, it's not terribly difficult to do the two mouse clicks to load the global profile.
You should probably post it as an idea, not a problem ticket. Problem tickets are for fixing equipment and software problems when it doesn't act as designed. Ideas are for feature requests.0 -
Yes, I did Post the option on start as an Idea but I reported the problem as a bug because Persistence should be handling Active Slice just like it handles other Slice properties. But for now "that's the way it works".0
- 419 Community Topics
- 718 The Flea Market
- 226 SmartSDR+
- 472 SmartSDR for Mac
- 282 SmartSDR for iOS
- 270 SmartSDR CAT
- 225 DAX
- 397 SmartSDR API
- 143 Aurora
- 389 FLEX-8000 Signature Series
- 1K Genius Products
- 366 Tuner Genius XL
- 139 Antenna Genius
- 334 Shack Infrastructure
- 237 Networking
- 150 Contesting
- 149 Amateur Radio Interests
