PowerGenius Tuner
Rich - N5ZC
Rich - N5ZC Member ✭✭✭
edited August 2020 in Tuner Genius XL
Has the tuner debuted at the Flex Booth.  If yes how about a pic.
Rich - N5ZC
«1
  • Steve K9ZW
    Steve K9ZW Member ✭✭✭
    edited May 2017
    Exhibition prototype shown. Ranko said it will be controlled via the amp's touchscreen. 73 Steve K9ZW
  • Larry - WA7LZO
    Larry - WA7LZO Member ✭✭
    edited May 2017
    Any pics of the Tuner?
  • Steve K9ZW
    edited May 2017
    When I get some connectivity I'll put one up.
  • Larry - WA7LZO
    edited May 2017
    Thanks, Steve!
  • David Orman
    David Orman Member ✭✭
    edited May 2017
    Sounds great Steve, thank you! If you took pictures of the FRS booth/gear in general, they would all be appreciated. How wide ranging is this tuner?
  • Steve K9ZW
    edited November 2018
    image Lash up for the show. Final unit will differ. 73 Steve K9ZW
  • Tim VE6SH
    Tim VE6SH Member ✭✭
    edited March 2019
    My understanding is the tuner will now come with the Power Genius ordered in 2017. Tim VE6SH
  • Larry - WA7LZO
    edited November 2019
    Steve, Will it fit inside of the PG XL amp? Thanks! Larry WA7LZO
  • Steve K9ZW
    edited December 2018
    @Tim - I understood that ones delivered in 2017 would include the tuner. The kit to remote the tuner is an optional extra. @Larry - Ranko said it would fit behind the tuner rather than under it. 73 Steve K9ZW
  • Tim VE6SH
    Tim VE6SH Member ✭✭
    edited March 2019
    Yes. I should have said delivered. And yes i understood it would fit behind the amp with an option to remote. Tim VE6SH
  • Rich - N5ZC
    edited October 2017
    What's with the 3 knobs sticking up towards the back of the unit?
    Rich - N5ZC
  • Doug - W5WTX
    Doug - W5WTX Member ✭✭
    edited January 2019
    The prototype FLEX tuner has three coax connectors.  Do you know if that is 1-in / 2-out or 2-in / 1-out?  Have not seen that question posed or answered.
    Doug - W9PN/5
  • Steve K9ZW
    edited June 2017
    I don't recall if they were labeled.
    The unit was one of their "test mules" prettied up as a "lash up" for the show according to Ranko.
    Would look to the production unit spec for connectivity.
    BTW there was a fourth control - the red "stick" button that was brought up through the cover and signs of possibly a few more that were not brought out on this show display unit.
    Hoping that Ranko 4o3a will post more information and pictures of a unit closer to the ones we will see with the PowerGeniusXLs when they deliver.
    Steve K9ZW
  • Burch - K4QXX
    Burch - K4QXX Member ✭✭
    edited July 2018
    The only bummer about the tuner is it will only tune 3:1 SWR from what I have been told.
  • Steve K9ZW
    edited July 2018
    @Burch - That was the rating for the amp Without the Tuner. I think Ranko had quite a number circa 9:1 with the tuner inline. Wish I had a better 80m and 160m antenna option, as I need a tuner only for those two bands due to compromised antenna sizes. 73 Steve K9ZW
  • Rich - N5ZC
    edited October 2017
    I think I read the tuner will handle 4:1 and the amp will handle 2.5:1 without a tuner.
    Rich - N5ZC
  • Steve K9ZW
    edited June 2017
    Correct - my typo mistake as 4:1 and 2.5:1 are correct.
    https://community.flexradio.com/flexr...
    Thanks for catching my mistake.
    Steve
    K9ZW
  • Burch - K4QXX
    edited June 2017
    I emailed Flex sales on May 31st and asked about the tuner and they said 3:1. I hope that is not correct but that's what I was told.  I still have the email I received.
  • Tim - W4TME
    edited June 2017
    One in, two out
  • Burch - K4QXX
    Tim, can you confirm the SWR range for the tuner?  The other thread said 4:1 but when I emailed Flex sales they said 3:1.
  • Tim - W4TME
    edited June 2017
    The FAQ quotes "The TunerGenius S will tune 15 to 200 ohms at 2 kW." which would be a 4:1 VSWR.  If I learn otherwise, I'll update the FAQ and make a point to add something to this post.
  • Burch - K4QXX
    edited June 2017
    Ok, thanks
  • Rich - N5ZC
    edited June 2017
    So if 4:1 is the rating at 2kw, Maybe its a bit better at 1.5kw.
    Rich - N5ZC
  • Burch - K4QXX
    edited June 2017
    The new elecraft amp includes a tuner but it is only 3:1 at 1500 watts.  Their brochure says the range is better at lower power levels so maybe that is the case with the Power Genius.  I guess I am spoiled with my cheap MFJ auto tuner as it has a range of 20-1600ohms.  It's good to 1500 watts.  Of course it took me two tries to get one that works! :)
  • HCampbell  WB4IVF
    HCampbell WB4IVF Member ✭✭
    edited June 2017
    I doubt that there is much consistency among most published autotuner specs, so comparing them may be apples and oranges.  For example, my LDG is advertised as being capable of matching a 10:1 SWR, but sometimes can’t get a match at much lower SWR (especially on the low bands).   I’ve heard the same about other brand autotuners.  When my LDG can’t get a match I have to switch in my manual tuner.  I suspect some claimed SWR numbers are "best case", and the real SWR limits could be lower depending on the complex impedance encountered, frequency, power level, etc.  Possibly the Tuner Genius is spec’d more conservatively than others.
    Howard
  • Tim - W4TME
    edited June 2017
    ATU specs are usually done with purely resistive loads.  Once you start presenting the tuner with really "squirrely" reactance, then that is when things get really interesting.  With a "quantized" tuner (as opposed to variable capacitance and impedance) if you are in between step values, you may not get a good match.
  • Ria
    Ria Member ✭✭✭
    edited June 2017
    There's only so much you can do with toroidal inductors before they begin to saturate. At some point you have to go to roller inductors and that is more expensive and complicated (motors). So most tuners will be 3:1.
  • HCampbell  WB4IVF
    edited June 2017
    Thanks Tim and Ria!  I’ll probably go with the Flex tuner due to its integration with Power Genius  - not to mention it coming free with the Genius!  (-:
    BTW for anyone who’s interested, here’s an excellent article on autotuners by Adam Farson that I found helpful when I got back into the hobby several years ago and was trying to catch up on progress since I became inactive:
    http://www.ab4oj.com/atu/main.html
    Howard
  • Ned K1NJ
    Ned K1NJ Member ✭✭
    edited June 2017
         Will a weather-proof enclosure be made available for the tuner?
       Ned, K1NJ
  • Varistor
    Varistor Member ✭✭
    edited June 2020
    I really don't understand why would anyone prioritize a fairly expensive amplifier before proper antennas and matching at the feed point. Can some please explain why you would not want to build good antennas and instead would rather use a tuner? I get it that many hams have significant space restrictions, but even then there are plenty of good options for single or multi-band resonant antennas that can deliver SWR under 2. A well built OCF- a compromise antenna by all standards- can do better than 2:1. IMHO, using an amp with antennas that have SWR higher than 2:1 makes no sense and is a waste of money.
