VPN in SmartSDR 2.0
John Cooper
Will SmartSDR 2.0 still support VPN operation with or without SmartLink? Can SmartLink turn the DC radio power on and off remotely?
I use OpenVPN for a VPN connection to my server giving me WAN access to my 6500. This link is used for more than just the radio. I have backup drives on this connection as well as bash script commands to turn the FlexRadio power on and off remotely. I'm not sure how SmartLink is going to fit into my scheme.
John / WB3AYG
John / WB3AYG
First of all, VPN operation isn't officially supported. It's just something that works.
As long as your VPN looks to the radio like it's on the LAN it will work. At least that's how it works for me.Can SmartLink turn the DC radio power on and off remotely
Not that I know of.1 -
The radio has to be powered on for a client to establish a SmartLink connection.
Using a VPN with SmartLink is redundant. I can imagine a configuration that might work, but it is really convoluted.
And as Ria said, VPN is transparent to the radio.0 -
Let me ask a possibly dumb question:
If I want to turn my antenna rotor from my remotely located Maestro as well as log contacts, how does that work with SmartLink?
Seems like I still need VPN to reach the rotor?0 -
Rotor is Easy. PSTrotatator has a web server program that gives you a web page for your.rotor I normally leav DDUTIL running on my PC at home to control my SteppIR albeit you can also do so if you direct connect the SteppIR to the Radio USB I also use DDUTIL to remote contra my SPE 2K-FA albeit again you can controlitfirectly from your radio USB Why DDUTIL because it allows much more control such as reverse SteppIR antenna and power control on Amp. Personally the Maestro is far to big and heavy and has too small a display to be useful in remote operations except when I need Contest ergonomics. SSDR for iOS on a 12" iPad is much easier, HAS DX Spots on Display and has integrated logging With V2. No need for VPN Curently sitting n my apartment in Paris Remoting via my station KY6LA in San Diego Just worked S57DX. Saw him on my ipad spot. Kicked on my Amp called and Qin the log. Easy.1
Yes you still need VPN to do it. I would like to see integrated rotor control in the future. I hope Flex decides to pick up on it.2
You still need to log on to vpn to access the rotor, no?1
No. I us the PSTRotator.exe web app. Port forward0
Ideal remote needs a web app to display and control Amp, Rotor SteppIR1
Plus need DIGITAL POWER METER SWR Or basically what DDUTIL Does in a Web App or browser window1
So your rotor control is left open? Is it at least password protected?0
Are you suggesting putting PSTrotatorAZ web server in DMZ?0
One last question. I take it I can use SmartSDR V2.0 without using SmartLink. Hopefully, that will let me see the radio on the VPN and also let me run my other server gadgets.0
Yes, you can.0
DMZ not necessary. Just port forwarding. And ddns.
PSTRotator is one of the best paid ham radio utility apps I've ever bought.0 -
But is there any security since your rotor is exposed on the public internet, like at least a login screen?0
None except I turn on the server remotely only when I am using it0
Thank you Ria, That'll work fine.0
- 246 Community Topics
- 488 The Flea Market
- 7.3K Software
- 328 SmartSDR for Mac
- 241 SmartSDR for iOS
- 224 SmartSDR CAT
- 161 DAX
- 343 SmartSDR API
- 8.5K Radios and Accessories
- 768 Maestro
- 42 FlexControl
- 726 Genius Products
- 251 Tuner Genius XL
- 84 Antenna Genius
- 222 Shack Infrastructure
- 149 Networking
- 118 Contesting
- 116 Amateur Radio Interests
- 810 Third-Party Software
