SoftEther VPN install script for Raspberry Pi
2»
  • K1IMD
    K1IMD Member
    edited May 2017
    Ria,
    It has been a little nuts here at work.  Hate it when work gets in the way of ham radio!!  Anyway, I ran the updated script and it executed perfectly.  I will test it later tonight to ensure it works properly but I suspect it will.  Still no smoking gun on the intermittent connection issues...
    Jon
    K1IMD
  • Ria
    Ria Member ✭✭✭
    edited May 2017
    Push come to shove we can try TeamViewer sometime.
  • Mark Burton
    Mark Burton Member
    edited November 2019
    Hi Ria, thanks for the script.
    It worked well once I figured out that eth0 was hardcoded into the vpninstall.sh script, as I am running Raspbian Stretch the interfaces are all renamed so had to tweak it to find the interface. Unfortunately I just hardcoded it, not sure how to fix it properly to make it dynamic.
    Mark
  • Mark Burton
    Mark Burton Member
    edited September 2017
    maybe update vpnsinstall.sh to use something like
    for f in e*; do [[ -e $f ]] || continue; echo $f ; done | head -1
    to get the wired interface and then use that to update commands.in
    bridgecreate VPN /DEVICE:enxMAC:ADDRESS /TAP:no
    and when echoing
    echo "Hardware address/MAC address:" 'cat /sys/class/net/enxMAC:ADDRESS /address' echo "IP address:"                   'ip addr show enxMAC:ADDRESS  | grep "inet " | cut -d '/' -f1 | cut -d ' ' -f6'
  • Ria
    Ria Member ✭✭✭
    Yep I guess I could do that, but this was just a simple script I threw together because others were asking me to help them get theirs going. I've stopped maintaining it since we have Smartlink and v2.0.
  • Ria
    Ria Member ✭✭✭
    I've really not maintained it all that much, but figured it was due for a minor update. I've updated the version of SoftEther used as well as not hardcoding eth0. I've also made the source code available on github in case you guys want to do your own things with it:
    https://github.com/rjairam/softether-scripts
    I used Makeself for the packaging.
  • K1IMD
    K1IMD Member
    edited May 2018
    Thank you so much Ria... Some of us are still using PowerSDR on older Flex gear and this is just what the doctor ordered!
    73JonK1IMD
