FLEX 6300 (2 month old) looses more and more output power, every mode, every band, hardly maximum 8
Thanks for the data. We are working with you via the HelpDesk for resolution0
Guy - unlike golf, more is better than less.1
Thanks Tim. I am #13400.
I had a simalur problem when my 6300 was new. The help desk had me run a few tests. Nothing helped. They sent me a shipping ticket to send the radio back to Texas. They fixed it and shipped it back. It averaged around 96 watts of output, that is close enough for me. Flex paid the shipping to and from the service center, good deal.0
Could someone tell me were uk owners send there radio for service,my 6500 is out of warranty.thanks0
Well, maybe there a voltage drop that develops along the PCB traces over time,
maybe time to check ohmic drop (voltage drop ) to PA deck internally or PA class AB bias shift ( Check with FRS on how to proceed )
I use an external linear so I have a Poor Man's 100Watts output at about 85Watts here not a show stopper here with Flex6700 at 13.8Vdc applied.0 -
FRStack has meters built in to read the DC voltage during TX as well as the output power and reflected power. You need to maintain 13.8 volts during TX. Here is a link.
http://www.mkcmsoftware.com/Flex/Index
Besides the meters is also has many other features you may find useful.
73's0 -
Tony - it is in Germany. It is explained on our website. You need to open a HelpDesk support ticket to start the process.
http://www.flexradio.com/support/service/0 -
Michael - in general, most of the issues are IR drop before the radio, not inside the radio. The use of power distribution blocks and in-line fuses can add to the overall resistance leading to the radio getting less than the required 13.8 VDC needed to make full power.0
- 383 Community Topics
- 638 The Flea Market
- 144 SmartSDR+
- 434 SmartSDR for Mac
- 273 SmartSDR for iOS
- 261 SmartSDR CAT
- 200 DAX
- 958 Maestro
- 57 FlexControl
- 934 Genius Products
- 342 Tuner Genius XL
- 303 Shack Infrastructure
- 142 Amateur Radio Interests
