6600 or 6600M......Here its the DILEMA
YV5WZ
Ok I'm gonna reserve Flex 6600.....but.......I don't know which one....I guess 6600 would work with maestro. and..I wouldn't have to change my Shack Room ....by other side 6600M would take me far away from windows updates nightmares.....
What do you think?
Best Regards
George, YV5WZ / PY3ZZZ
What do you think?
Best Regards
Before opt'ing or the 6600M, I'd first make darn sure it has the control abilities to perform all the functions as the Windows driven 6600.
They all still work with SmartSDR on Windows, so you would still have your nightmares.... but if it were me... I don't want another Maestro, so will probably go for the 6600.1
George, I suppose it depends upon what you plan to do with it in addition to sitting in front of it. Do you need to use DAX? Will you need to link it to your computer for logging? You may still need Windows. But that isn't what determines the need for the M model. That will be determined by your operating style. I have put a deposit on a 6600, figuring that my style of operating works well with the Flex Control Knob and DDUtil macros. Later I will finish my MIDI controller project. It the controller worth another $1000 to you? If so, get it. It is nicely done.1
Isn't the Maestro a windows tablet with added controls? How does that free one of Windows nightmares?1
I understood 6600M is free from use with any PC... Did I understand wrong?0
I have taken same path that you did....your MIDI proyect made me curious hahahaha0
I did..... reserved 6600....0
Just to be clear...MY midi project only refers to the particular way I plan to modify it for my particular station... William started it, I jumped in for a while and then got sidetracked, and the recently several others have picked it up, one eve porting a version over to C#, which is what I had hoped to do eventually. So I can claim very little credit for it.0
You CAN use it as a stand-alone rig. And it will work well. But most hams will connect to a computer of some sort for logging, digital modes, etc.1
Will the 6600M have the DAX control on the computer or in the rig?
Will the 6600M offer access to all 4 slices when used as a stand-alone rig?
answer to #1 - DAX will be installed & run on the PC where you have the 3rd party software installed.
Ken, I am wondering the same thing. The M models will have HDMI outputs on the rear of the radio. I wonder if that is driven by a tablet like the one in the current version of Maestro, or if the new radios will have onboard proccessors for video. Maestro doesn't suffer from Win10 updates like a normal Windows PC can. The version of Windows in Maestro doesn't auto update. FRS controls the update proccess not Microsoft. Of course, FRS could include a Win10 update in their updates that could cause problems. But, I think FRS vets the updates well enough to avoid that as much as possible. James WD5GWY0
So, if I get the 6600M, can I also choose to operate the radio from a PC, with full blown mouse, using an external monitor connected to the PC or the 6600M, etc, thus enjoying the best of both worlds, or will there be some mixed use limitations?
My plan, at this point, is to roll a 6600M, also use my PC, and also order a Maestro II, so I can stay in touch, whilst sipping my Vente Latte at Starbucks, where there is also a Level 3 charger for my soon-to-arrive Tesla Model 3!
Br,
Larry
WA7LZO
you can block any windows computer from accessing Windows update by any number of measures, including putting it on a non-internet accessible network, having the computer directly wired to the FlexRadio with a simple cat5e cable, not setting a gateway IP address, etc. The computer you control your flex radio with need never be on the internet.0
Initial roll out of 2.0 only supports one client at a time, meaning PC or Maestro, not both at same time.
The multi-client simultaneous operation is on the radar. Not sure what version will ship with the 6400M and 6600M and if the initial roll out will support PC and HDMI at same time.
- 636 The Flea Market
- 144 SmartSDR+
- 261 SmartSDR CAT
- 199 DAX
- 45 Aurora
- 957 Maestro
- 57 FlexControl
- 931 Genius Products
- 302 Shack Infrastructure
- 141 Amateur Radio Interests
