WSJT-X Lost Rig Control Upgrading to SmartSDR 1.10.16
David Ahrendts
David Ahrendts Member ✭✭
100% smooth upgrade to SmartSDR 1.10.16, but I appear to have lost rig control (frequency follow and PTT) with WSJT-X 1.7.0. It is decoding and it does produce tone to the Flex 6500, but does not key the transmitter. What did I do?
  • Al K0VM
    Al K0VM Member ✭✭✭
    edited December 2018
    If you have not already done so, reboot the PC and verify that SSDRCAT is running.  Then verify that WSJT has the correct SSDRCAT port selected.  In SSDRCAT, that comport should show 'Process wsjt'.
    AL, K0VM
  • David Ahrendts
    edited May 2017
    Al, thanks. Will do. Certain that SSDRCAT is running, Not certain the ports are correct. Checking tonight.
  • Al K0VM
    Al K0VM Member ✭✭✭
    edited May 2017
    May need to verify that a port conflgict with another device was not created..
    AL, k0VM
  • Dudley-WA5QPZ
    Dudley-WA5QPZ Inactive Employee
    edited March 2018
    If SmartCAT is not connecting to the radio ,  might want to do the Repair on FlexVSP  .
    https://helpdesk.flexradio.com/hc/en-us/articles/205665325-How-to-Repair-the-FlexVSP-Virtual-Serial-...
  • Ian1
    Ian1 Member ✭✭
    edited May 2020
    Check the setting in WSTX make sure nothing changed the last upgrade changed some on my 6700. Ian
  • David Ahrendts
    Gentlemen, thank you. There was a port inconsistency. Corrected and all is working again. Thanks.
    David A., KK6DA, Los Angeles
