WSJT-X Lost Rig Control Upgrading to SmartSDR 1.10.16
David Ahrendts
100% smooth upgrade to SmartSDR 1.10.16, but I appear to have lost rig control (frequency follow and PTT) with WSJT-X 1.7.0. It is decoding and it does produce tone to the Flex 6500, but does not key the transmitter. What did I do?
If you have not already done so, reboot the PC and verify that SSDRCAT is running. Then verify that WSJT has the correct SSDRCAT port selected. In SSDRCAT, that comport should show 'Process wsjt'.
AL, K0VM
Al, thanks. Will do. Certain that SSDRCAT is running, Not certain the ports are correct. Checking tonight.0
May need to verify that a port conflgict with another device was not created..
AL, k0VM
If SmartCAT is not connecting to the radio , might want to do the Repair on FlexVSP .
https://helpdesk.flexradio.com/hc/en-us/articles/205665325-How-to-Repair-the-FlexVSP-Virtual-Serial-...
Check the setting in WSTX make sure nothing changed the last upgrade changed some on my 6700. Ian0
Gentlemen, thank you. There was a port inconsistency. Corrected and all is working again. Thanks.
David A., KK6DA, Los Angeles0
- 246 Community Topics
- 488 The Flea Market
- 7.3K Software
- 328 SmartSDR for Mac
- 241 SmartSDR for iOS
- 224 SmartSDR CAT
- 161 DAX
- 343 SmartSDR API
- 8.5K Radios and Accessories
- 768 Maestro
- 42 FlexControl
- 726 Genius Products
- 251 Tuner Genius XL
- 84 Antenna Genius
- 223 Shack Infrastructure
- 150 Networking
- 118 Contesting
- 116 Amateur Radio Interests
- 810 Third-Party Software
