Smart s-Meter Plus download
Bob G W1GLV
If anyone is looking for Woodbox Radio SmartSDR Meter Plus, use this llink to my dropbox.
https://www.dropbox.com/s/nt5hp1g07q1azr6/Smart%20S-meter%20Plus.zip?dl=0
2
Thank You Bob,
Larry
ke2yc
Where would I look for the Setup instructions. Downloaded fine, but need help setting CAT/Port communication.0
Will this run on W10? I get a message that it won't.0
There were instructions?0
Hi all,
Just loaded on Win 10 and needed to download Net Framework 3.5 which has 3 and 2 in it. Have not tried in smartsdr yet as I am repairing my power supply. It does boot the meter in desk top. As soon as I get supply back together will try in smartsdr. Follow readme file and you should be ok.
Larry
ke2yc
very easy, click on the S(setup), next pick an unused com port. If the comport is OK it will tell you. Save & Exit.0
Thanks. Tried that several times. In Setup, selected port (#34) and got "Cat Port Ok!" Selected "Save & Exit", Port #34 showed up on S-Meter. then clicked "Start" but still no joy. I must still be missing something.
Bob, really neat and easy to install. Works great. Glad I came across your note. Been wanting a "real" S meter for my 6300. TNX for the link and TNX to IK4IRO & IK3VIG for writing the app.
Bob, K2OID
Dave, I was having the same issue, until it dawned on me that the CAT Port selected probably needed to be one showing up in the "SmartSDR Cat" panel.
That was my "duh" moment for today. :-)
Tom -- Thanks for the tip. What I found out is that slice A was running WSJT-X and that CAT port was always busy. When I switched off the digital, BINGO !. I had tried looking at SmartCAT, but now see the reason it did not work. Now i claim my "duh" moment for today! More fun!
Dave0 -
I've been running it W10 since it was introduced, no biggy.0
I'm glad you're enjoying it. Great smeter.0
FYI: This link is no longer working. Might want to update or **** this thread.0
This is previously from Howard KY6LA: https://www.dropbox.com/s/223si9ks962n1av/Smart S-meter_V1.6.zip?dl=0
- 634 The Flea Market
- 135 SmartSDR+
- 198 DAX
- 42 Aurora
- 956 Maestro
- 299 Shack Infrastructure
- 211 Networking
