USB cable from the 6700 directly to a USB port on the Raspberry PI 3
Mark - NU6X
USB to USB port on a Raspberry PI 3
2
Is there a question lurking in there somewhere?0
I haven't posted in a long time.... it posted before I finished typing the question.
I will try this again....I want to connect the USB port on the 6700 rear panel directly to a Raspberry PI 3 USB port that is the controller of a linear. The Raspberry PI is programmed for the standard Kenwood and Flex commands. I have read the USB manual and other post and all I see is FTDI to serial or Parallel. This is USB to USB connection. Does it require a special cable?0 -
As far as I know from Alpha you must use an FTDI approved chipset device. I see where your going here, I think your gonna need a couple of serial interfaces, one for the flex and one for the Pi... then interpret the data coming into the Pi via serial... I think...
I suspect that the Pi could be programmed to act like a FTDI device and programmed to act like one of the devices that the Flex USB interface supports and then to take that data and control the amp, but I doubt that it would work as-is. A second possibility would be to have the Pi connected to the Ethernet network and to use the Flex network protocol to talk to the Flex and whatever interface to talk to the amp. Again this would require custom programming of the Pi.0
Mark, but maybe we can found a solution that Flex and PA can communicate via LAN. Then no need for a USB connection.
And still open question is: need a good Amp a interface connection to TRX - if PA always check the frequency , switch automatically Band and Auto Tune do his work alone ....0 -
I think that the new Flex Power Genius Amp monitors the Flex via LAN and adjusts the amp accordingly. For amps without a LAN interface, it should be possible to develop a program that runs on a small computer, such as the Raspberry Pi that monitors the Flex via LAN and controls the amp via whatever interface/prootocol the amp supports. Last year, I bought a Rasberry Pi with the intent of doing that for my SPE Amp, but before I got around to it, Flex added USB support for that amp.0
.... mark please buy onother Raspi now - maybe it push FRS again for new things :-)0
It's trivial to connect the radio via Ethernet on a pi using python.
VITA-49 Discovery using udp packets could be dumped into a python dict, struct or other object.
Slice frequency data can be read using tcp streams from the radio.
Put that in a loop and spit out to your B26-PA control app. You can even do T/R switching if you like.
Presto.
No need to wait on flex.0 -
Back of the napkin function for discovery (haven't tested this but it should work)
#!/bin/python
import select, socket
def discoverRadios():
"discovery"
port = 4992 # Flex VITA-49 port
bufferSize = 1024
s = socket.socket(socket.AF_INET, socket.SOCK_DGRAM)
s.bind(('', port))
s.setblocking(0)
result = select.select([s],[],[])
msg = result[0][0].recv(bufferSize)
radio = dict(s.split('=',1) for s in msg.split(" "))
return radio
How you call it:
while radio is None :
radio = discoverRadios();
radio will be a dict object, for example if you want the radio's IP it will be:
print radio ['ip']
Similarly you can use tcp streams to get the per slice frequency.
Ria Edit: oops, looks like GS destroyed my indentation. Oh well, if you know python you can figure it out
- 392 Community Topics
- 665 The Flea Market
- 171 SmartSDR+
- 446 SmartSDR for Mac
- 266 SmartSDR CAT
- 210 DAX
- 387 SmartSDR API
- 66 Aurora
- 310 FLEX-8000 Signature Series
- 979 Maestro
- 952 Genius Products
- 349 Tuner Genius XL
- 129 Antenna Genius
- 310 Shack Infrastructure
- 217 Networking
- 829 Peripherals & Station Integration
- 145 Amateur Radio Interests
