PowerGenius XL
Thank you Craig for the update, please don't be a stranger here, your insights and real life experiences with the Flex and PGxL are invaluable.0
Since a legal limit antenna tuner is about $1500, if it will tolerate SWR up to 2.5:1 that's pretty good. All my antennas are below 2:1 on the frequencies I use. Thanks.
73, Bill W6WRT
QSK on CW?
Tim,
What are the dimensions of the Amp including projections. I'm going to build a shelf to slide under and need to know what the height is including feet. Looks like cooling is handled front to back so I shouldn't need much clearance on the top, correct?
Rich - N5ZC
The dimension specs are on the website. On the back, I'd add an inch for the connectors. Cooling is front to back. Since the case is also part of the thermal mass of the unit, you will need some clearance on the top. Probably a few inches.
http://www.flexradio.com/amateur-products/
Thanks Tim,
So the 5" height spec includes the feet?
Rich - N5ZC
The Beta is 6.5" from the front feet to the top cover....but of course this could change in production.
73, Craig K9CT0 -
Thanks Craig for the info0
I would be very surprised if it wasn't.0
Thanks Craig,
Working on either a desk location or my rack, haven't decided yet. There's pros and cons to both.
Rich - N5ZC
- 378 Community Topics
- 116 SmartSDR+
- 923 Genius Products
